Lg 50pz560t
  • bevaloid
    • Mar 2015
    • 13
    • England
    Lg 50pz560t
    I have an LG 50pz570T with a black screen and no sound. It started when I switched on, changed channels and the whole screen turned a light purple then switched off. Have checked all the voltages as given in the service manual and they all check out OK. The standby led lights when plugged in and goes off when the on button operated and there is a very slight hum coming from the Y board so I am suspecting that but not been experienced enough I don't know. Any help would be most appreciated
    Re: Lg 50pz560t
    Would you be able to supply pictures of the parts inside the set?
    Do you have a digital multimeter available and do you know how to use it?
    Pink tint sounds like Z sustain ("Z board" or "X-main")
    • bevaloid
      • Mar 2015
      • 13
      • England
      Re: Lg 50pz560t
      Thanks for replying Tom .yes I do have a multimeter and am able to use it. As I said previously I have checked all voltages as described in service manual.All panel voltages plus all on connecters between boards.I am a bit pushed for time right now, work calling.I can sort some pics out later. But I have the service manual with all detailed pics.But I don't know the ruling on sending that. Thanks again
      • bevaloid
        • Mar 2015
        • 13
        • England
        Re: Lg 50pz570t (correction)
        My apologies for not getting back to you sooner but here are some pics from the manual hoping they will be of help ...thanks
          Re: Lg 50pz560t
          Can you not supply pictures of your boards? The reason is, we can see some signs of damage/overheating, and sometimes manufacturers change boards mid-production.
          • bevaloid
            • Mar 2015
            • 13
            • England
            Re: Lg 50pz560t
            will do
            • bevaloid
              • Mar 2015
              • 13
              • England
              Re: Lg 50pz560t
              These are the best pics I can get. If you require the rear of the boards I will have to strip them down later. The green led on the control board flashes but doesn't seem to follow a set pattern. As I said previous all the voltages on each board tally with the manual.
                Re: Lg 50pz560t
                Can you get a picture of the sticker that has the internal plasma panel model number on it, e.g. "PDP50L9#####", will be marked, e.g. "LG Electronics Made in Poland". Note, this is NOT the back label with "50PZ560T" on it...
                • bevaloid
                  • Mar 2015
                  • 13
                  • England
                  Re: Lg 50pz560t
                  Thanks for your patience Tom. Here's the picture of the panel label.
                    Re: Lg 50pz560t
                    Ok, see page 139-149.
                    Follow steps on pg 143 & 148 to measure -Vy, Vsc and Vzbias.
                    DO NOT ADJUST ANYTHING YET. You do not need to use white wash as set is non functional and we just need a quick reading.
                    • bevaloid
                      • Mar 2015
                      • 13
                      • England
                      Re: Lg 50pz560t
                      The vsc reads 149.8, the vzb 124.9 and the vy 190.2v minus in reverse
                        Re: Lg 50pz560t
                        Make the room as dark as possible (curtains closed, ligths off) - any glow from the screen, even slightly?
                        • bevaloid
                          • Mar 2015
                          • 13
                          • England
                          Re: Lg 50pz560t
                          As the on button is touched or remote button pressed the screen actually brightens momentarily as though its coming on then back to black.
                            Re: Lg 50pz560t
                            This board: https://www.badcaps.net/forum/attach...9&d=1426254676
                            There are two holes next to R54, R53, place a wire jumper between them and disconnect right most ribbon cable going to the main board.
                            Plug the set in.... what happens, any test patterns, display light, etc?
                            • bevaloid
                              • Mar 2015
                              • 13
                              • England
                              Re: Lg 50pz560t
                              White, red, green, blue, grey then half screen horizontally moves across then vertically.
                                Re: Lg 50pz560t
                                Good, provided screens look OK then main board is bad. Sigh, another bad LG plasma main board.
                                (This is the board with HDMI inputs, etc. on it.)
                                • bevaloid
                                  • Mar 2015
                                  • 13
                                  • England
                                  Re: Lg 50pz560t
                                  Thanks for all your help Tom, strangely enough I usually watch films via USB a couple of weeks previous it wouldn't work then a couple of nights later it did work so maybe it was the start of the failure I don't know.Do you happen to know where to source these or is it not worth it.Thanks again
                                  • sordids999
                                    • May 2013
                                    • 2160
                                    Re: Lg 50pz560t
                                    Normally Ebay,Google search EAX63525104 i think thats your board but ill be surpised if you find one LG main boards are very rare to source
                                    • bevaloid
                                      • Mar 2015
                                      • 13
                                      • England
                                      Re: Lg 50pz560t
                                      See what you mean been checking I notice there's a place that repairs them may give them a bell.....Thanks
                                      • Ally18
                                        • 8
                                        • United Kingdom
                                        Re: Lg 50pz560t
                                        Hi sorry to bring up old thread but I have same tv same problem as poster. For the life of me I can't find R54 or R53 to put a jumper wire to. I have same board as in the photo part numbers are the same
                                          Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                                          09-07-2024, 12:40 AM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • gjgib
                                          Help reading schematic voltages input/output
                                          by gjgib
                                          Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                          I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                          I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                          I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                          05-06-2024, 08:11 PM
                                        • karlp028
                                          MSI Z390-A PRO missing VCORE voltages
                                          by karlp028
                                          I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                          06-23-2025, 01:25 AM
                                        • lol999
                                          Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                          by lol999
                                          Motherboard after starting show Q code 00.
                                          No shorts on any rail ( at last I can't finde any)
                                          All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                          Nothing get hot, PSU starting, all lights came ON....
                                          One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                          After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                          This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                          01-21-2024, 02:25 PM
