Dead LG 32PC5RV Plasma TV
  • JimsMonitors
    • Aug 2013
    • 7
    Hi All!
    I have an LG 32PC5RV plasma TV that is not functioning. When I power it on, it get an odd buzzing-type noise from the power board for about 2 seconds and then it stops. This is coincident with the green power LED coming on solid for about 1 to 2 seconds and then starting to flash about 16-17 times. After these flashes, the power LED goes red. If I turn the power off then back on, the cycle repeats itself. The power board and the YSUS board look fine (no hot areas, no obvious blown capacitors). I have tried connecting a video/audio source and cycling through the inputs but no audio or video appeared at all. Any idea where the problem might be?
    Thank you.
    Jim
  • JimsMonitors
    • Aug 2013
    • 7
    Re: Dead LG 32PC5RV Plasma TV
    Hi all!
    I did some voltage testing and I get a steady 4.95V on the 5V Stby pin. Prior to activating the power button, there is a very low voltage (~0.3 mV) on the other non-ground pins. When I depress the power button, for about 1 second, the voltage on the other pins jumps up to the levels indicated on the PCB. Then they drop back down to zero. I have to wait for about 15 or so seconds before I can try again. This corresponds to the 16 or 17 flashes of the power LED that I mentioned in my previous post. Once the power LED turns red, I can re-activate the power switch and repeat the behavior. Throughout all this, the voltage level on the 5V Stby pin remains steady at about 4.95V. Can anyone suggest any other tests I could try to see if I can isolate where the problem is?
    Thank you.
    Jim
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Check for shorts on Vs line--particularly to the Y-SUS/X-SUS.
      Unplug the power cable from X-SUS--does set start up and give sound?--obviously with no picture.
      Unplug power leads from Y-SUS, does set start up?
      TELEFIX
      • JimsMonitors
        • Aug 2013
        • 7
        Good Day Alastair!
        Thank you for taking the time to offer some suggestions.
        The Vs line seems fine. I disconnected both ends and there appears to be good continuity on the two individual Vs lines with no shorting between the lines.
        Before disconnecting the X-SUS power connector, I checked the voltage levels on the 5V lines going into the X-SUS board. As described earlier, for about 1 second shortly after powering on the set, the voltage level shows at about 4.9V then immediately drops to zero. Same on both 5V lines.
        When I disconnected the power connector to the X-SUS board, there was no change in behavior to what I described in my first post. The TV itself produced no sound (i.e. like a power-on "chirp"). It just made the electrical buzzing sound on the power board as described earlier.
        When I then also disconnected the power lead from the Y-SUS board, upon powering on the TV, that electrical buzzing sound was no longer present. As well, the green power LED only flashed 3 times before going steady green for 1-2 seconds then turning red. Again, no audio produced by the TV.
        Any other suggestions as to what I might try next?
        Thank you.
        Jim
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Hmm--Didnt mean to check like that!
          With set off, Check the resistance of the Vs line on Y-SUS plug to metal chassis of set with the PSU disconnected from Y-SUS.
          Do the same with the X-SUS....
          If a low resistance is found--then that board has shorted IGBT's and or diodes on it....
          If no shorts--Whats the Vs Voltage when you first turn set on, everything connected?--Should be around 180-200V
          TELEFIX
          • JimsMonitors
            • Aug 2013
            • 7
            Hi Alastair,
            Sorry for the misunderstanding. I'm pretty new at all of this.
            Here's what I found:
            The resistance on the two Vs lines is very high (on the order of 350 Mohms). But it is not consistent. When I first touch the lead to the Vs pin in the connector, the resistance spikes very high and then gradually decreases. The same behaviour happens on both Vs pins in the Y-SUS board connector (with the plug from the PSU unplugged). Similar behaviour and resistance levels were experienced on the X-SUS board, though there is no Vs pin on the X-SUS - just two 5V lines.
            When I reconnect all the connectors and power up the set, the voltage level on the Vs lines in the Y-SUS connector max out at 100-110 mV - nowhere near 180-200V.
            Thank you for your patience! Any next thoughts??
            Jim
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Hmm-- You said earlier, the Y-SUS made a very slight buzzing sound...
              --IME this would only be present if the Vs was at or around the correct value.
              Can you describe exactly How you're measuring the Vs and Va supplies...?
              TELEFIX
              • JimsMonitors
                • Aug 2013
                • 7
                Hi Alistair,
                The buzzing sound I mentioned is coming from the PS board and only occurs when the cable from the PS board to the Y-SUS is actually connected to the Y-SUS board. And this buzzing is louder than what I would consider to be a normal or acceptable level of electrical buzz on a power board.
                When I measured the voltage levels on the Vs lines, I inserted the positive lead into the connector (the end of the cable that attaches to the Y-SUS board) while the connector was still attached to the Y-SUS board. I connected the negative lead to the metal frame. I then applied power to the board (plugged the unit into the mains and depressed the power switch on the front of the TV) and observed the results on my DMM. I also used the MAX function on the DMM to see the level that the voltage got to before the set automatically shut down again after a couple of seconds.
                Back to you my friend!
                Jim
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Well--With no shorts on the Vs line Y-SUS, and no voltage at all when the set is turned on, it could well be the PSU board. The Z-SUS is incorporated on the Y of these sets as far as I can find, the board on that side has just a couple of diodes on it....
                  --To confirm, a picture of the Y would be good....
                  What does the pin on PSU marked, 'PS-On' to when you turn set on?
                  TELEFIX
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Andreas_de
                    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                    by Andreas_de
                    Hello!
                    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                    04-12-2025, 10:38 AM
                    03-31-2024, 02:12 PM
