sony KDL32EX650
  • smali
    • Sep 2014
    • 287
    • Pakistan
    sony KDL32EX650
    This is my first post in this section and i hope that i will be get knowledge and help from experts because i am laptop technician.
    today i have received a sony LED TV KDL32X650 for repairing .
    the TV is dead no standby LED showing
    i checked some measurement on PSU on CN6401 ..i received only 3.3v i think which is standby voltage and study some thread related and got a matching schematic not same but matching.
    no other votage on CN6401 except 3.3v.
    i checked the voltage on IC (A3810m) VCC pin 19 which have 3 volts only and this pin also showing with ground 15ohms which i think showing short. i disconnect only the VCC pin from circuit now that line receiving 12 voltage and no short circuit showing but the disconnected pin of IC still showing 15 ohms with ground pin which i think yhe IC internally short but what you experts are suugest....
    the attachecd diagram is matching not same because in the diagram used IC CXA3809M which little different VCC PIN and also different PCB codes.
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: sony KDL32EX650
    sorry i forgot the attachment.
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Re: sony KDL32EX650
      please help regards ic cxa3810m on primery side on PS board?is this is faulty 15ohms VCC pin with GND pin as detail said above.please help
        Re: sony KDL32EX650
        cxa3810m has the same pinout as cxa3809m?
        Lift up VCC off the board and check the resistance across filter caps C6113, c6322 to see if it still show 15 Ohms.
        • smali
          • Sep 2014
          • 287
          • Pakistan
          Re: sony KDL32EX650
          Thanks for your reply sir,
          As you said i lifted thhe VCC pin from PCB now the 15ohms resistance not showing on PCB or across the c6322 but lifted of the IC still showing 15 ohms resistance with GND pin.and also receiving 12volts on C6322 but when connect VCC pin of the IC thhe volts come down to 3 voltage.
            Re: sony KDL32EX650
            The resistance between the VCC pin (lifted) and the Gnd pin should not be 15 Ohms for sure, so you do have internal problem inside the IC.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8325
              Re: sony KDL32EX650
              Do we get to see any hi res pics?
              Sounds like the IC is toasted.
              • smali
                • Sep 2014
                • 287
                • Pakistan
                Re: sony KDL32EX650
                OK..i want to know about out put volts on secondary side of PS on standby condition.
                please guide me is there any volts should be present except 3.3v.
                  Re: sony KDL32EX650
                  Right now you will not have UNREG24V, REG12V which are generated by transformer T6302.
                  The IC6301 (CXA3809) is the muti-function for the PFC Voltage booster circuit, the SMPS for the UNREG24V, REG12V, it also does the AC DETECT function feeding the Main board.
                  When the power supply board receives POWER-ON (>2.5VDC) from the main board, the PFC Voltage and the 24V/12V will startup (the 12V/24V requires boosted Voltage from the PFC circuit to run.
                  It is complex setup, you should download the specification of the CXA IC to learn how it functions.
                  • smali
                    • Sep 2014
                    • 287
                    • Pakistan
                    Re: sony KDL32EX650
                    Thank you Sir.
                    • anmol
                      • Mar 2012
                      • 73
                      • India
                      Re: sony KDL32EX650
                      Here is Sony_1-883-924-11_CXA3810M-T6_[SCH]
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:27 AM
                        Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                        This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                        09-06-2024, 05:30 AM
                        Sony VAIO VPCEE3J1E/WI E Specification for Upgrade or Repair
                        This specification for the Sony VAIO VPCEE3J1E/WI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEE3J1E/WI boardview and VPCEE3J1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
