New tool, Aoyue 8800! Desoldering just got easy!
  • Nerfinator
    • Feb 2015
    • 56
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    How does it work? I use braid and pumps for my de-solder work but always looking for something to make it go faster. Time == $$$$
    • lookimback
      • Aug 2013
      • 1489
      So far, I'd say it works really good.
      ------------signature starts here------------
      • capkid
        • Oct 2010
        • 1339
        http://youtu.be/mEgRHT1EqVA
        http://youtu.be/aC0d-WhHdZM
        LG Plasma Mal-Discharge Correction Service
        • lookimback
          • Aug 2013
          • 1489
          I bought mine from sra-solder, but through their eBay store because it was $10 cheaper there. I wish they made a tip that could fit over the pins on large heatsinks. I guess that's my only complaint, but from what I can tell, none of the other brands make such a tip either. Maybe I'll buy a spare 1.8mm tip and bore it out.
          • capkid
            • Oct 2010
            • 1339
            You can also add solder then suck up the solder on either side of the pin - this should clear the hole. You'll need lots of heat, so a heat gun is a must.
            • lookimback
              • Aug 2013
              • 1489
              Originally posted by capkid
              You can also add solder then suck up the solder on either side of the pin. You'll need lots of heat, so a heat gun is a must.
              I have a heat gun. A remnant from my home improvement days. I use it, very carefully, to warm up boards so the heat doesn't disperse as quickly when I'm desoldering . I also have a hot air station.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                #27
                So Aoyue finally ripped off the Hakko 808?
                -David VanHorn
                • lookimback
                  • Aug 2013
                  • 1489
                  So it would seem.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    #29
                    Wonder how long before Kada etc rip off the Aoyue!
                    Desoldering guns are pretty awesome compared to the one-shot pumps. But even those and braid are still good sometimes, desoldering gun doesn't work for everything.
                    I have a Den-On gun type one but I think I would prefer a station. I don't like the vibration from the pump motor. It seems to make it easier to damage pads sometimes.
                    -David VanHorn
                    • lookimback
                      • Aug 2013
                      • 1489
                      They could use a better label. It's not like this was cheap. $180, I think a foil label wouldn't cost more than a quarter.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4951
                        • New Zealand
                        #31
                        Maybe you should be glad, they might have used the money saved on the sticker to give it better quality wiring.
                        -David VanHorn
                        • lookimback
                          • Aug 2013
                          • 1489
                          Good point.
                          • Nerfinator
                            • Feb 2015
                            • 56
                            WOW! I'm sold.
                            • Nerfinator
                              • Feb 2015
                              • 56
                              That size, probably about .05/ea after volume pricing. I use to order custom foil labels from Uline for my concrete gnomes that my boys and I make.
                              • lookimback
                                • Aug 2013
                                • 1489
                                I hate to even have to revisit this thread and say this, but this thing is less than a month old and already has issues. The pump motor bogs down sometimes and then the suction is crap. I don't know if it's the motor itself, or just a bad connection. I haven't used it more than 10 times. I guess I'll tear it apart and see what it is. If you want one of these, I'd suggest saving up a bit more and getting a Hakko. Also, I think one where the pump is in a station rather than the gun would be better. Aoyue just lost me as a customer.
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  The Hakko 808 I bought was only $170 or $180. The only issue I've had is not an issue with the gun itself: The tips can become clogged and rendered unusable if you suck up flux. The flux becomes hard like concrete and is difficult to remove. I haven't found a removal method that doesn't also damage the tip. Also, I haven't encountered a need to have a station separate from the gun. What were your thoughts in that regard?
                                    • 31012
                                    i had a weller ds80, the cleaning is always a problem on vac tools.
                                    to get the flux and other crap out of the end, use a drill-bit that is smaller than the hole when it's cold.
                                    and if you use it a lot, empty the collector and inspect the filter atleast once a day.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      Less vibration would be the only real benefit.
                                      I took this apart, I don't know why I didn't take pics of the internals. I know I should be banished for that. Anyway though, I'm certain it's the motor. It has no markings, just a sticker that says No. 1064. I'm going to try to return it, even if just for an exchange. If that doesn't happen, I'll try to find a replacement motor, maybe something of higher quality.
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        I'd think an overnight soak in acetone would dissolve the flux.
                                          This is my past experience with Aoyue.
                                          I bought an Aoyue 968 and had far too many issues with it. Soldering iron failure, hot air heater failure, pump noisy/shaky, etc.
                                          Never again will I buy an Aoyue.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
