Panasonic TX-P46G10E - A-BOARD problem?
  • oluja74
    • Feb 2015
    • 10
    • Serbia
    A couple days ago TV started acting strange. See video.
    https://www.youtube.com/watch?v=rMQla4RVRZc
    After couple attempts it starts up normally. Picture and sound are all ok, like nothing happened. It works all day perfectly normal. Tomorrow morning it is all over again, like in the YouTube video.
    When it fails to turn on, red light indicates error 1. in the Service Manual. See picture below.
    When it finally starts working, TV completes self check without errors. See picture below.
    Is A-BOARD fawlty or is it something else?
    Thanks in advance
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TX-P46G10E - A-BOARD problem?
    100% A-board. taking a guess but maybe one of the BGA chips has fractured solder joints and needs reflowing or reball/replacement. Temperature could be causing the fault to be intermittent but I'd expect it to get worse and permanent.
    You could try warming up the board with a hair dryer and see if that allows you to turn it on first go.
    • oluja74
      • Feb 2015
      • 10
      • Serbia
      Hot air soldering did not help. But, we have new behavior now. It's turns on normally, picture is fine, but in a couple seconds starts displaying vertical lines like before...
      When i open TV i took a picture of the main board (TNPH0784), maybe someone find it usefull someday...
      [img=http://img212.imagevenue.com/loc1061/th_324054415_TNPH0784_122_1061lo.jpg]
      • oluja74
        • Feb 2015
        • 10
        • Serbia
        Does anyone know if the mainboard from Panasonic TX-P46G10B TV can be used as an adequate substitute for the same board in TX-P46G10E?
        As fas as I am aware, the only difference is that the B has the net connector and the E does not.
        B version of the main board is on the left side of the picture and on the right side is the E version:
        • oluja74
          • Feb 2015
          • 10
          • Serbia
          I have replaced these capacitors and for now TV works fine
          • tw2005
            • Oct 2011
            • 6458
            any chance you upload a picture which can be enlarged? I'd love to see which ones
            • oluja74
              • Feb 2015
              • 10
              • Serbia
              Big picture. Both sides of the board...
              [img=http://img148.imagevenue.com/loc178/th_109629871_P1470453_web_122_178lo.jpg] [img=http://img231.imagevenue.com/loc548/th_109639653_P1470456_web_122_548lo.jpg]
              • tw2005
                • Oct 2011
                • 6458
                Well that's interesting because someone has mentioned an intermittent 1 blink fix replacing caps before but never said which ones.
                So it's 100% reliable now?
                And all those circled you replaced?
                So was that just a hunch or did you remove and test those?
                I like simple fixes that save people a lot of money which this would given how expensive and rare A boards can be as these age.
                • oluja74
                  • Feb 2015
                  • 10
                  • Serbia
                  Originally posted by tw2005
                  well that's interesting because someone has mentioned an intermittent 1 blink fix replacing caps before but never said which ones.
                  Just in case we replaced them all
                  so it's 100% reliable now?
                  Not 100% First two mornings it tuned on with error 1, red blinking diode, like in the beginning... last three days it turns on normally and works all day perfectly fine...
                  and all those circled you replaced?
                  All of them, just in case...
                  so was that just a hunch or did you remove and test those?
                  We notice stains in places where caps are, it was suspicious so we checked them out and half of them where bad, see the picture
                  i like simple fixes that save people a lot of money which this would given how expensive and rare a boards can be as these age.
                  I like it too Hope this helps someone else in the future
                  • tw2005
                    • Oct 2011
                    • 6458
                    Nice, I think it may because every now and then we get a post about intermittent 1 blink. And I'm pretty sure quite often it's 2009 models the same gen as yours.
                    I've proven a corrupt eeprom can do the same but it was a solid 1 blink never intermittent, that was the next gen after yours, x20 model
                    • oluja74
                      • Feb 2015
                      • 10
                      • Serbia
                      I've managed to acquire Main Board for UK market (TNPH0811 for P46G10B) and it works.
                      BUT, there is no sound in cable TV channels because UK system is PAL I and where I live its PAL B/G. There is no option in menus to change that to be like in the model for continental Europe...
                      Picture from User Manual for TX-P46G10E, there is option for changing PAL system.
                      Is there an option in Service Menus to change SC2 to SC1 (PAL system)?
                      • Neelix
                        • Oct 2013
                        • 145
                        • South Africa
                        Had similar issue before with a Panasonic Plasma TV that somebody brought in from another country. Through the RF input the picture is good, but no sound(only hissing). Could not find any option in the user or service menus to change to a different sound frequency
                        • tw2005
                          • Oct 2011
                          • 6458
                          may have already mentioned this but if you can get the service manual for your version and the version of the other markets A board, compare the EEPROM, Flash chips etc and determine which are the same.
                          he others will be where the differences lay and so provided those chips are ok and not corrupted just swap them over.Ideally Boards would have to have the same physical layout like same input/outputs
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • Bazfletch3
                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                            by Bazfletch3
                            Hi all
                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                            From there I envisaged that the backlighting wasn't working, however...
                            01-08-2024, 10:18 PM
                          • dhs6512
                            Lenovo Legion 5 15ACH6H Starts, greeting sound, no picture anywhere
                            by dhs6512
                            Hello. Lenovo Legion 5 15ACH6H 82JU PF303BT1, board HY660 HY661 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0 2021-01-25.
                            Starts up, the keyboard backlight lights up, the sound of the Windows 11 password entry window loading is heard, the backlight brightness is adjustable on the keyboard,
                            when pressing caps or numlock there is an indicator, there is no picture either to its own or to an external one via HDMI. I checked the board under a microscope, ok, clean and untouched.
                            I threw in a matrix (FHD, 40 pin, 144Hz), flashed the BIOS (official, took the latest gkcn65ww and one earlier...
                            08-23-2024, 07:35 AM
                          • renech
                            panasonic TH-42PC77U plasma television half screen problem
                            by renech
                            hello,
                            I hope someone on this forum can assist me.
                            I have a panasonic TH-42PC77U plasma television.
                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                            I have read some posts that suggest the problem is related to the boards on the left...
                            12-12-2022, 06:53 PM
                          • doorzon
                            AOC AGON AG273QCG refresh problem picture shifts
                            by doorzon
                            hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                            The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                            See attached picture.
                            I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                            However, this could also be related...
                            08-12-2023, 02:36 AM
