LG 60PA6500 - blank picture wont boot
  • skyver
    • Feb 2015
    • 31
    Hi all glad i found this forum bit of an odd one
    My switches between either
    * constant relay click
    or
    * stuck in some standby mode where the screen is on but blank , power LED is red and control board D101 LED blinks fast, then slow, then pauses
    weird thing is every now and again the TV works fine for a few days then back to this and there was no precursor to this occuring
    when its in its constant relay click boot, it will do this with just the power and main board connected with all other boards unplugged
    when its stuck in the blank screen mode i have completed an auto gen test and the screen cycles through different colours, so from what ive read that means its a mainboard problem?
    what can i test on the main board?
    POWER SUPPLY EAX64276701/11 EAY62609801
    Mainboard is an EAX64696607 (1.0)
    Re: LG 60PA6500 - blank picture wont boot
    You can check the voltage regulators on the board. Posting a picture of the board would help us help you...
    • skyver
      • Feb 2015
      • 31
      Thanks for the reply. This is the main board
      Where are the voltage regulators on here? I'm only aware of one on the smps board and don't know how to test that .
      • skyver
        • Feb 2015
        • 31
        Symptoms have now changed to a 3rd one with no intervention.
        * Just a contant standby light and relay doesn't click when the power point it turned on (is it meant to?)
        No blinking led on control or constant red on main board
        • skyver
          • Feb 2015
          • 31
          I tested the power board by jumpering the pins on the power lead that goes to the main board
          Relay clicked once and screen was on just black , so looking more and more like hte main board
            Your test of the control board confirmed the main board is the cause of the fault. I don't see any obvious voltage regulators you can check.
            • skyver
              • Feb 2015
              • 31
              if i get a new main board for overseas i presume i will have to swap over the tuner EBL61120001 component?
              Ive found a few voltage regulators but they are tiny and only one specifies the volts in and out 2.5 > 2.5
              • skyver
                • Feb 2015
                • 31
                found schematics for the circuitry for this TV 60pa6500-TM
                starting to go through the voltage regulators
                eg IC601
                +3.3 in
                +2.5 out
                Is there anyway i can supply just 5 volts to this board of the TV for testing these?
                  You should test in situ, i.e. board powered in standby by main board. If it is not coming out of standby, it does not matter if a main voltage regulator is unavailable, that will not be causing it.
                  • skyver
                    • Feb 2015
                    • 31
                    mmm all the voltage converters appear to be doing their thing is there anything else common on this board that breaks ? i redid any solder joints that didnt look exact and no differnet, Its stuck in the relay click mode at present and again with main board disconnected its no problems
                    • skyver
                      • Feb 2015
                      • 31
                      cant find my version of main board anywhere, as mine is a 60pa6500-TM
                      • skyver
                        • Feb 2015
                        • 31
                        ok so ive come back to this and its now in a new fault state the TV is just in standby now.
                        I still haven't been able to source another main board yet.
                        If i bypass main board i can power on and do the test image display so i know power and control is still OK they havent changed.
                        With main board in when i power on at the wall:
                        > No relay click
                        > No LED on main board
                        > No LED on control board
                        > power button on remote does nothing
                        > power button on TV does noting
                        > Front standby LED is on
                        any idea what this fault should be leaning towards?
                        If not i might just get the only other main board that looks suitable the 60pa6500-UG ill need to remove the remote in plug and swap tuners though
                        • skyver
                          • Feb 2015
                          • 31
                          When I bridge the connectors on the lease whilst plugged into main board relay clicks on and off so that to me says something is actually shorting out on the main board. I tried a full reflow with a heatgun no change.
                          I'll keep updating this till I work it out
                          • skyver
                            • Feb 2015
                            • 31
                            Can someone help with this
                            So with present scenario its just in standby with no relay click.
                            These are the readings from the power waver (input cable)
                            Are these correct?
                            These are taken directly of the pins on the board
                            I have no voltages on any of hte voltage regulators but presume this is because its in standby?
                            • skyver
                              • Feb 2015
                              • 31
                              so these 3 are:
                              17 - M_On
                              15 - RL_ON
                              13 - STDBY 5V
                              in standby they are meant to be the following according to LG doco
                              17 - 0V
                              15 - 0V
                              13 - 3.49v
                              Im getting the following when reading this off the mainboard or SMPS.
                              17 - 3.29v
                              15 - 2.54v
                              13 - 3.43v
                              I also noted the incoming [Error_Det] has 3.41V
                              Does this indicate anything in particular?
                              So this should indicate the main board is sending the RL_ON command to the SMPS?
                              But im thinking because its also sending Error_DET to SMPS its not coming on?
                              Anyone got any ideas? any other places i should be taking readings?
                                If you have >2V on RL ON, 5V ON, etc. the power supply voltages should be OK. I think the main board is turning on the PSU ok (whether or not it should - some LG sets will turn on immediately as power is applied but others will only turn on when commanded via the remote) but it's not sending any video output over the LVDS cable...
                                • skyver
                                  • Feb 2015
                                  • 31
                                  ye it wont get out of standby though, relay will never click on, with power button or remote. I know the button section is working as 3.3v is supplied there and red LED on front is on. Would an issue with sending over LVDS only be if it was actually powering on ?
                                  i can get the relay to click for a second and led comes on main board if i bridge - RL_ON and M_ON , did it by accident, guess this would result in sending 5+ volts over RL_ON.
                                  Tracking down voltages at the moment only odd thing ive notived is what i think the eprom has voltages of 5.5V & 5.4V instead of 5V, unsure if this means anything
                                    MAX3232 is not an EEPROM (or flash memory IC), it is a logic level driver for computer control of the TV. Connects to RS232 port. If you are unsure on what a part does take its part number and google it.
                                    Do you have Vs/Va?
                                    • skyver
                                      • Feb 2015
                                      • 31
                                      Do you have Vs/Va?
                                      no va vs On the output cables off the powerboard.
                                      There is if I remove the mainboard and it powers on automatically.
                                        you may have to jumper VS ON/RL ON/5V ON signals.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • CyTECH ELECTRONICS
                                          Xbox one Series S blank picture no boot
                                          by CyTECH ELECTRONICS
                                          I'm middle of doing this console and just wanted to ask about a component if someone seen one of these.It looks like a fuse or a coil but I measure nothing no resistance or anything.It's related to the hdmi section and connects ground to an ic.I'm a bit confused at this point.Anyone can confirm what it is?Please only need advice from who actually worked with one of these.Thanks
                                          05-02-2024, 10:03 AM
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
