I'm middle of doing this console and just wanted to ask about a component if someone seen one of these.It looks like a fuse or a coil but I measure nothing no resistance or anything.It's related to the hdmi section and connects ground to an ic.I'm a bit confused at this point.Anyone can confirm what it is?Please only need advice from who actually worked with one of these.Thanks
Xbox one Series S blank picture no boot
by EximHi guys,
I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
ASRock N100M special features:
- CPU soldered to board, small Intel 12th gen
- iGPU
- four POST LEDs
Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
Symptoms:
- no picture/signal on any of the display connectors,...2 Photos -
by erdosgreetings
My old homebuilt pc won't boot for some reason, when I pressed power on, I can hear Power supply fan running, but no bios screen, just blank and DVD-rom LED flashing.
I've switched with a different graphics card (known good) to no avail. the pc is equipped with corsair 550W power supply and a MSI K8N Neo Platinum Mob.
How do i check which part is the culprit for causing the issue?... -
by TMTGTRFirstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
=>Background:
I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ... -
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... - Loading...
