Two 42PQ10s Power Boards
  • Michale32086
    • Nov 2011
    • 1453
    Sometimes the stars align.
    I have 2 42PQ10s. One is a Zenith and the other is an LG.. They are identical in layout..
    On the LG, when I power up the unit, the red LED comes on, then turns blue. Then 2 blue blinks, then goes solid red... The relay does a double click..
    On the Zenith, when I power up the unit, there is no relay click and the LED just does a stuttered red blinking..
    When I switch the Power boards on the units, the same symptoms occur. In other words, the symptoms follow the Power boards...
    This tells me that the Power boards are bad.. Safe assumption??
    One of the Power boards (the one that does the red then blue blinks then red) has MOSFET written on the heat sink.. A clue!??
    So, my first thought is to simply replace both the power boards.. But that wouldn't be much fun and wouldn't help me this weekend...
    So, my second thought was to take the mosfet off the one board and put it on the other board that is marked with (what I assume is) the mosfet problem..
    How does my logic track???
    Re: Two 42PQ10s Power Boards
    Blown fuse & FET is somewhat common on these. But, you should check the P/S output voltages before condemning the power supply. Maybe both your Y-sustains are bad? Your swap the PSU test wouldn't make any difference in that case, and you'd be needlessly swapping boards.
    • Michale32086
      • Nov 2011
      • 1453
      Changing out the marked Mosfet didn't help..
      On both units, VS and VA is zilch. zero...
        Well... if the FET was shorted, what else might fail?
        • Michale32086
          • Nov 2011
          • 1453
          I am haggling with ShopJimmy on a pair of boards. But it sure would be nice to track down the problem on one board using parts from the other.
            Think about the question I asked. I have fixed the same PSU. Easy fix.
            (Don't just replace "it" straight away, though... some other things need to be tested)
            • Michale32086
              • Nov 2011
              • 1453
              Without a schematic, i could only W.A.G.
              • Michale32086
                • Nov 2011
                • 1453
                Awwww, who am I kidding. Even with a schematic, it would be a Wild Assed Guess
                  Check the fuse with the blue band on it.
                  (One of them looks to have been replaced already... but did the previous guy miss something?)
                  • Michale32086
                    • Nov 2011
                    • 1453
                    OK, lemme pull the board and start tracing..
                    • Michale32086
                      • Nov 2011
                      • 1453
                      The FET goes to the fuse on the mid board.. The fuse checks out, but looks a little hinky on the TRACE side..
                        Have both FETs been replaced?
                        When repairing a SMPS stage, it is always recommended to replace any FETs directly connected to each other. This is a half-bridge converter, so the SOURCE of the TOP FET is connected to the DRAIN of the BOTTOM FET. If the top FET fails, excess current can flow into the bottom FET, damaging that too; the same applies for the bottom FET damaging the top one. It is also often necessary to replace the IC that drives the FETs, which is a small surface mount device, on this board it has 14 pins.
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Judging from the flux, it looks like 2 were replaced, plus the big part off to the left.. The one in red is the one that's marked on the component side of the board..
                            Are these devices shorted or OK?
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Don't appear to be any shorts on any of them..
                                Ok, with the board installed & TV powered up (you will have to do power up whilst measuring), what is the voltage across the capacitor nearest the 14 pin IC (electrolytic, on the top side)?
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  The only IC er... I see.. on the topside (component) is a 28pin IC.. Is that the one you mean??
                                  I am gonna get the wife. I'll take this unit home if yer gonna be around for a bit..
                                    It's on the bottom - little surface mount thing - the capacitor is NEXT to it, but on the TOP... does that make any sense... if not I will highlight it.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Yea, I know which one you are talking about. It was shown in one of the pics above..
                                      Let me unpack the unit from the car and I'll check it..
                                      Thanx..
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        The IC under the board is the red box so I assume the cap you need is the one in the green box..
                                        One sec
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Thomas Smith
                                          Asus Tuf gaming fx506l no power, mosfet does not open
                                          by Thomas Smith
                                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                          Initial Symptoms:
                                          • The laptop has no power at all (no LEDs, no fan spin).
                                          • No 3.3V or 5V present on the board.
                                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                          Power Rail Checks:
                                          1. Charger input (FETs PKCH2BB)
                                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                          2. BQ24780S Charger IC:
                                            • VCC and ACDET are present.
                                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                            • Shunt resistor has 10Ω to ground.
                                          03-30-2025, 03:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • vexarvf1s
                                          Acer: No power after first MOSFET no short? Looking for guidance.
                                          by vexarvf1s
                                          Looking for guidance in tracking down missing main power rail.
                                          I have an Acer that I am working on. It runs on the battery, but does not charge. I changed the power adapter and same thing battey not charging, and continues to discharge. So I opened the computer and started looking for the problem to fix.
                                          First thing I checked is if the power form the charger is getting to the mainboard. I found that 19V is going all the way to the first MOSFET. So DC jack is fine. However I do not have power past the first MOSFET.
                                          So checked for voltage on the gate of the first MOSFET and...
                                          05-13-2023, 07:55 AM
