Phillips 42PFL3704D/F7 No Standby Power
  • simcole
    • Apr 2014
    • 30
    So I have a TV (Phillips 42PFL3704D/F7) I've been struggling with. When I plug it in, it does NOTHING. I do not see the 5V standby light. I downloaded the service manual and went to the trouble shooting section for the power supply board. It suggests after checking the fuse to see if "There is any leak or short-circuiting on the primary circuit component and service it if it's defective. (C1205, D1205, D1206, D1207, D1208, Q1203, Q1204, T1201)".
    I've taken all the diodes 1205-1208 out of circuit and tested them. They all tested fine. I checked C1205 via a $20 ebay circuit tester w/ LCD screen (LCR-T3 tester). It checked ok too. I finally pulled the Q1203 and Q1204 out and tested them with the same device; the problem is I don't know how to read those results. Here these are:
    Q1203 is a FET 2SK3757(Q) pic of it being tested attached below
    Q1204 is a Transistor KTC3199-GR-AT/P (says C2120 on part) pic of it being tested attached below
    Finally I have NO idea how to test the T1201: TRANS POWER 9705 LTT1PC0KT003
    Could one of those 3 things be causing this? If those things are working correctly the next troubleshooting step is "Is the AL+5V line voltage normal?" It is normal and I found that. Also the 3.3v line is normal.
    Any help is appreciated.
    Finally it says test T1201 which I guess is a
  • simcole
    • Apr 2014
    • 30
    Re: Phillips 42PFL3704D/F7 No Standby Power
    Here is a full size picture of the board.. I tried to get it in focus. I made notes on here that you can see in black letters and arrows.
    If you look at the diagram I attached (I have the YA1A serial number), I'm getting NO VOLTAGE at the CN1803 white connector. I should be getting panel +24V on pings 1-5 and I'm not. Maybe someone can tell me where else to look now.
    • CapLeaker
      Leaking Member
      • 8225
      I hope all the parts are back in the power supply. Plug it in an take your DMM and check the DC voltage on the big filter cap.
      • simcole
        • Apr 2014
        • 30
        So I'm not familiar with the term "Big Filter Cap" but I assume you mean the big transformer T1201. All parts are back in the board and plugged in. I put my DMM common to a cold side ground and ran my red lead to all pins on the DC side from 9-16. I get NO DC voltage of any kind. Is that how I test this thing? Is it bad?
        part LTT1PC0KT003. If this is the thing that's bad I can't google a replacement part.
        • simcole
          • Apr 2014
          • 30
          Actually if you mean the big black capaicitor on the hot side, I tested that with it plugged in on DC volts. I get no voltage.
          Edit: I took it out of circuit and put it in my tester. It tested ok, but I still didn't get voltage AC OR DC on it when it was plugged in.
          • philliesfan30m
            • Aug 2013
            • 542
            are you checking that cap with the negative lead on the negative leg of the cap and the positive on the positive leg? when checking on hot side you have to use the negative leg of cap as ground not the chassis. you have to have some kind of voltage on the big cap or you wouldn't be getting any voltage at all.
            • philliesfan30m
              • Aug 2013
              • 542
              high voltage there so be careful up to 400vdc
              • philliesfan30m
                • Aug 2013
                • 542
                can you post a pic of all of the boards connected
                • CapLeaker
                  Leaking Member
                  • 8225
                  The filter cap you should be testing is C1201. Did you actually verify that there is no standby voltage? Did you unplug the ribbon cable and measure again?
                  • simcole
                    • Apr 2014
                    • 30
                    Ok. Yes I tested the voltage by placing negative lead on cap and positive lead on cap as well. I initially tested C1612 which gave no voltage DC
                    I tested C1201 in circuit and read 171 volts DC. It reads it should be 350V. Ill pull it out of circuit in a minute and test it with my LCD tester.
                    • CapLeaker
                      Leaking Member
                      • 8225
                      No need. That voltage is correct. 120AC gives you about 170V DC.
                      Now check C1103 and C1112.
                      • simcole
                        • Apr 2014
                        • 30
                        C1101 - 3.2vdc
                        C1103 - 5.2vdc
                        C1104 - 5.2vdc
                        C1112 - 13.6vdc
                        Thanks for the responses so far. I followed the trouble shooting flow chart, but I'm at a loss for now. What next? I'm kinda excited to see what you suggest.
                        • CapLeaker
                          Leaking Member
                          • 8225
                          Check the bridge rectifier D1601 and see if you get any DC out of it.
                          The 24V for the backlight wont come on until the power supply is turned on, and the backlight gets the BLon voltage (usually 5V). The STBY voltage is always on at the power supply and feeds the main board. Once you press the power button, that STBY voltage goes back to the power supply and turns on the rest of the power supply rails. So, I think the power supply is producing the STBY voltage, but there might be something going on at the main board not turning on the rest of the power supply. So verify that the STBY voltage reaches the main board. Maybe you find a blown fuse on the main board.
                          If you connect the main board and the standby disappears, you got a short. If it stays on and no reaction from the main board, something is open or the main chip is fried.
                          Have a look at page 12-1, 9-5 or 9-6 (depends on your serial number) and 9-7.
                          So what happened to the TV? A lightning strike special or something?
                          • simcole
                            • Apr 2014
                            • 30
                            CapLeaker so with the power off I put my mm in diode mode and tested the bridge rectifier in circuit. I was getting .5's across the board which seems normal. When I plugged it in and tested the rectifier I got no AC or DC voltage. When I have all the boards plugged up together i can find my 5v making it across the ribbon cable to the main board. I haven't tried to find it down deeper on that board. The tv was one a neighbor was throwing away and I have no idea what happened to it. I'm trying to give it to my grandmother because she has an old small one and it would be nice to gift her one she can see better.
                            Talk to me more about what I should see on the bridge rectifier
                            • CapLeaker
                              Leaking Member
                              • 8225
                              Bridge rectifier D1601 doesn't get any AC until relay RL1201 is energized. It gets it's signal from the main board. Since you are getting 0.5V voltage drop across the 4 legs of D1601, she is all right.
                              Sounds like you got a bad main board.
                              • tvguy12012012120
                                by tvguy12012012120
                                02-07-2025, 05:13 PM
                              • fharris1977
                                Vizio D50u-D1 Dead Set No Standby
                                by fharris1977
                                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                12-28-2023, 10:25 AM
                              • Crystaleyes
                                Samsung BN44-00259A standby question
                                by Crystaleyes
                                Hi all.
                                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                08-11-2023, 05:15 AM
                              • psssst
                                Yamaha TSX 120 Standby Problem
                                by psssst
                                Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                03-01-2024, 07:25 AM
                              • ChristianBr01
                                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                by ChristianBr01
                                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                04-23-2025, 01:48 AM
