Samsung PN43D450A2D help needed
    Re: Samsung PN43D450A2D help needed
    There is one other test I can think of, but it is fairly involved. If you can find a way to attach two 120V light bulbs (in series) to the Vs output of the PSU (around 200V, two 120V light bulbs = one 240V light bulb) then that will provide a load to it, we will be able to see if the problem is that it cannot support load. (Plasma panels draw more power for brighter images, unlike LCD. This means the PSU might be able to work with a dim image, but as soon as a brighter image comes up, it shuts down.)
    If not, perhaps you can just try replacing the PSU anyway, take a chance on it.
    • Krenzy
      • Feb 2015
      • 45
      Ok, I replaced the Power Supply board, that didn't fix it. I then installed a new Control board, no dice. Finally, I installed a new Main board. That didn't fix the issue. All board are new from ShopJimmy, they're kinda local to me. So either they're selling faulty boards, which I doubt, or...I don't know. What's next?
      • Shinju
        • Mar 2014
        • 1239
        Bad Panel?
        I did not read the entire thread, I have repaired one of these and they are VERY fragile. Your issue is a strange one, did you replace the Ydrive buffer too?
        • Krenzy
          • Feb 2015
          • 45
          Not the buffer, but the Y main board.
          • Shinju
            • Mar 2014
            • 1239
            Have you checked the buffer for shorts?
            • Shinju
              • Mar 2014
              • 1239
              Tom66's video on how to do it!
              https://www.youtube.com/watch?v=51SZsfH60EY
                I don't see a panel issue causing this. I just can't imagine how it could do this.
                I noticed on the last D450 I worked on, that the X-main power connector had yellowed from all the Vsus current passing on just two pins. Perhaps over time this connector could overheat causing a Vsus sag? Worth taking a look.
                We've had this odd, image-dependent fault pop up before on plasmas - and it's been a power supply problem in almost every case. I reckon if you tried playing "dark" content on the screen (mostly light grey with very little peak white) it would play for a while. Hence why your shut down occurs on the first test pattern displayed (white)
                It's gonna be real fun when OLEDs come to the market proper - whilst plasmas vary from around 30-100% Vsus and 20-100% Va, OLEDs go all the way to zero on VCOM...
                • Krenzy
                  • Feb 2015
                  • 45
                  If I did it right, then my buffer is fine. I could not get my multumeter to beep buy was able to see the number on the gauge to verify the process was working.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Odd issue indeed, I voted panel only because that's the only part besides the YDrive buffer he hasn't replaced yet.
                    this is a strange fault for sure!
                    • Shinju
                      • Mar 2014
                      • 1239
                      Just for giggles, check each panel ribbon cable for wear damage, maybe something's grounding out?
                      • Krenzy
                        • Feb 2015
                        • 45
                        I inspected the ribbons and wires, nothing seems exposed or shows obvious signs of issue. Regardless, wouldn't a damaged ribbon or wire prevent the system from working fine before the issue hits?
                        When I plug in my HDMI cord to my phone to try and mirror that on the TV, it also trips it. What component is responsible for the image scroller/video? I tried tapping on all the heatsinks again, with no change.
                        • Krenzy
                          • Feb 2015
                          • 45
                          I did notice this: the two strips that plug into the X board have small tears in them. Would this affect it? How easy are they to replace? I noticed if I unplug one of them and hit the Media P button on the remote, I get a bright blue screen for had a second then the issue happens again, but it seems like it's more than I've seen before.
                          • Shinju
                            • Mar 2014
                            • 1239
                            Well, I would be willing to bet that is your problem. Did you just rip those out or did you actually pull them out correctly because it looks like those were ripped out as those holes are supposed to be the locks to keep them in place inside the connector.
                            • Krenzy
                              • Feb 2015
                              • 45
                              This is how they looked when I released them. My guess is the previous owner is responsible for this. How can I fix this? And what are they called?
                              • Shinju
                                • Mar 2014
                                • 1239
                                Well, those ribbons are permanently attached and glued to the glass panel I don't know how you can fix other than cutting them back but I would like to hear with Tom or someone with more experience as a first.
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Have you inspeced the YDrive buffer ribbons too?
                                  • Krenzy
                                    • Feb 2015
                                    • 45
                                    Yes those ribbons on the Y are all intact, no tears.
                                    • Krenzy
                                      • Feb 2015
                                      • 45
                                      I'm hoping Tom or someone has any advice on what to do with those ribbons.
                                        Can you get a picture of the other side, the metal side, of each ribbon?
                                        • Krenzy
                                          • Feb 2015
                                          • 45
                                          If you need a better picture let me know.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
