LG 50PZ550T Vertical Lines
  • anotherdude
    • Feb 2013
    • 488
    • uk
    Got offered this TV but not sure it's worth the time or money
    Tv turns on but displays this
    Seeing lots of main board issues with this model, so either that or the logic board?
    Re: LG 50PZ550T Vertical Lines
    Do the lines ever change?
    • anotherdude
      • Feb 2013
      • 488
      • uk
      I'm not sure, will ask, also found out the sound works but is intermittent
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • pni
        LG 49uf695v vertical coloured lines
        by pni
        Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
        11-14-2025, 03:15 AM
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
      • gpo23
        Sony KDL-40V3000 - Vertical lines
        by gpo23
        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
        With the new t-con the color are good but there are vertical lines on all the screen :
        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
        Is there a way to fix the vertical lines on the new t-con ?
        Thank you for your help
        gpo23...
        10-04-2023, 09:11 AM
