Sony KDL-52VL150 no picture nosound no back light
  • hienton2
    • Sep 2009
    • 183
    I have tv KDL 52vl150. I can turn on off tv with remote controle or button on panel .Tv has green led But that is it has no picture no sound no back light.
    I did update with KDL-52VL150_ER412_E328_M046.zip but no fix
    May be it is not firmware problem. I need help
  • PNI E.
    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
    by PNI E.
    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
    02-20-2025, 08:36 AM
  • koby058
    vostro comes up with back light but no picture
    by koby058
    Hi people!!
    The owner said it showed bad picture once in a while (attached)
    I see that there is back light but no picture.
    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
    Also attached schematic and BDV
    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
    07-13-2025, 01:03 PM
  • noisykid
    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
    by noisykid
    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
    12-30-2024, 07:15 PM
  • brithepi2k
    Sony KD-65XE8596 no standby light
    by brithepi2k
    I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
    cheers...
    09-06-2025, 02:22 PM
  • iglitare
    Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
    by iglitare
    i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
    Backlight seems to work, Sound (Setup menu after reset) works.
    If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
    Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
    With my small knowledge i would think at least the cables are good.
    Can this happen because of a bad tcon board?
    Or is it always a bad/shorted...
    09-04-2025, 07:13 AM
