Zenith Z50PT320
  • thekiltman85
    • Jan 2015
    • 22
    Zenith Z50PT320
    Good afternoon,
    I have a Zenith Z50PT320 TV that would click on then immediately back off. I systematically removed boards 1 by 1. When I removed the Ysus board and buffers the PSU stayed on consistently and no longer power cycled. I ordered a new Y sustain and Y buffers, as well as a new PSU. The new PSU was DOA but I installed the new buffers and y sustain board on the old PSU and the TV came on and stayed on power wise, however there is still no picture. The screen stays black and does not flicker. The TV appears to be in standby mode because the LED on the front is red. I can't verify if the TV has sound because I can't figure out how to switch the inputs to our roku device. We do not have cable. All told I need to buy a new multimeter and take readings I'm sure but i'm pretty amateur and just getting into this as a hobby. Any thoughts? Attached please find pictures of the inside of the TV.
    Best regards and happy hunting,
    Aaron
  • thekiltman85
    • Jan 2015
    • 22
    Re: Zenith Z50PT320
    I take it back. There is audio now on the TV just no picture. I'll check the ysustain board and Y buffers with a new multimeter hopefully some time this week and give an update. I have a hard time believing this board will be broken as the seller seems reputable and because I also received from another seller a clearly dead psu. Can I be that unlucky? What else can I try? Thanks again
      Re: Zenith Z50PT320
      Check all voltages, Vs, Va, Vsc, -Vy and Vzbias.
      Low Vsc/-Vy: isolate Y-buffer and test again. If voltages come back that indicates that buffers are likely shorted.
      • thekiltman85
        • Jan 2015
        • 22
        Re: Zenith Z50PT320
        Voila. Thanks for the advice. As it turns out I had ordered a replacement Y sustain board and buffers. The buffer boards ended up being as you said shorted. I used the new y sustain board, and old buffer boards and so far so good. I'll have to run it for a bit and see if the repair takes. As it stands right now the set works like brand new. Thanks again!
        • gatto
          LG 50PC56 keep burn Buffers Boards
          by gatto
          Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
          I have this LG 50PC56 which not display image on screen
          I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
          When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
          My question it is: I disconnect...
          05-04-2022, 01:35 AM
        • cmonkey
          Zenith Z50PJ240 - White Screen with 'Power Only' displayed
          by cmonkey
          Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
          I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
          Anyone seen this before?
          Thinking about it some more, it happened...
          05-19-2023, 01:01 PM
        • Keshenatech1
          LG 50PJ350 plasma blowing Y-Sustain board
          by Keshenatech1
          Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
          05-13-2020, 10:08 AM
        • csmith
          LG-60PN6550 Removing Buffers-Need Help
          by csmith
          Got replacement buffer boards but not sure how to remove the ribbons. unfastened tab but their not eager to come out. Any suggestions? Thank You!...
          08-21-2024, 01:34 PM
        • pete g
          zenith plasma tv. the model is Z50PX2D.pix problem
          by pete g
          hi, i have a zenith plasma tv. the model is Z50PX2D. i really love this tv. as of late its coming on with 6 vertical lines of white dots. they flicker, the audio seems to affected also with static sounds. all other aspects of the pic are good. i have good color, and no other problems with picture. can someone help? thanks.
          06-18-2022, 12:10 PM
