Bush lt32m1ca
  • Studley
    • Feb 2013
    • 18
    • Uk
    Bush lt32m1ca
    Hi everyone, just a quick question. I currently have a Bush LT32M1CA that has a solarised screen. I understand in most cases it's the chip on the T-Con that goes bad and myself have had a couple of Samsungs with this problem.
    In this case of this Bush tv though, the onscreen menus appear fine with no distortion. I have read and seen elsewhere that it's probably the main av board at fault as the onscreen menus are ok. Could anyone please clarify this prior to me ordering a replacement av board.
    Thanks in advance.
  • tyler123456
    Need help identifying an IC chip on a Bush DAB radio (BD-1801)
    by tyler123456
    Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
    I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
    I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
    Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
    Anyone...
    08-16-2024, 12:51 PM
  • FlailingEngineer
    Help with Bush Tv (Vestel 17mb95m Mainboard)
    by FlailingEngineer
    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
    05-31-2023, 06:52 AM
  • Johnny.p
    Bush WI-1810 Internet Radio
    by Johnny.p
    I recently bought an internet radio Bush WI-1810, it came with a power supply that when plugged in promptly damaged the radio. I discovered too late that the radio was 6v and the supplied adaptor was 12v. The radio still powers on but the wifi is not working. I have attached a few pictures- Image 2 showing the board with damaged component top right labelled U8. There are several other similar components like U9 (image 3) that I'm wondering could be a replacement.
    U9 has a code on it S5EJI- I have searched several smd code sites and the nearest I can find is for a mark of S5E -listing shows...
    11-25-2023, 04:18 AM
  • Peterguns
    Bios for Asus Tuf F15 FX506LH hidden menus unlock
    by Peterguns
    I need help!, need mod bios for asus tuf f15 fx506lh...
    01-28-2025, 02:09 PM
  • NYKing
    Hisense TV 32D33 - Replaced EEPROM, now menus have no text
    by NYKing
    The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
    https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
    I took off the old chip using my hot air station and soldered on the new chip. I tested...
    10-07-2021, 05:06 PM
