Hello all. I have a vizio e320vl that i need to update the firmware. I can't find any place to download it except for a few sites that I'm certain are full of malware. Does anyone have the firmware download for the mentioned model? I called vizio support and they were not much help and the website does not have a download page for the tv. Any help is appreciated.
vizio e320vl firmware needed
My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
During these seconds the function button is not working...2 Photos-
by EduCabralHi everyone,
I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
š§ Details:- Model: YT-M06
- Interface: Pioneer 1
- MCU: Fujitsu MB89F202
- Goal: Find a valid .bin firmware file or memory dump from a working unit
I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...-
07-15-2025, 12:26 AM -
I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
The content of these seems to be useless as far...-
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by Robby-GrHi all,
Iām trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality ā very close to the original.
However, since the swap, the TV enters a boot loop (Samsung logo ā restart) unless I enter the service menu and perform a reset.
The service mode had been previously modified ā possibly by a technician or during the panel swap ā and I suspect some key settings are mismatched for the European (Greece) market.
Additional issues:...11 Photos - Loading...
