Vistron ltm-4271e standby problem
  • quiggy
    • Aug 2014
    • 136
    Hello all
    I have a vistron TV which was stuck in standby and after replacing 5 caps it now comes out of standby but only when I've first plugged it in if I put it back into standby and try to turn it on the light will go green but no display I checked voltages and when it's on they all seem fine apart from standby voltage which is 2.6v and should be 5v when the lights green but Theres no display 12v reads as 0v same for 5v and standby. Any ideas? Sorry about the long sentence I'm on a phone. Thanks in advance
  • nomoresonys
    • 12330
    • U.S.
    Re: Vistron ltm-4271e standby problem
    maybe try unplug standby connector from power supply board to main board and see if you then have 5v at power supply, careful when working with power supply, HIGH VOLTAGE.
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • psssst
      Yamaha TSX 120 Standby Problem
      by psssst
      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
      03-01-2024, 07:25 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
      HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
      This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
      09-12-2024, 02:00 PM
