Overhead projector TV: Need alternative backlight source..
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi there,
    I've made an overhead TV projector with an LCD screen and an overhead projector... similar to this video..
    https://www.youtube.com/watch?v=b7lWqKHpGuc
    But I am having a problem that the head from the overhead projector kills the TCP joining the panel to the t-con board... The guy in the video has a 230VAC fan that he pins to the side of the overhead projector.. But even with this I find that the heat kills it...
    I was gonna use one of these. It's the same lumens as the overhead projector but runs coler..
    I was thinking about taking off the magnifying element from the overhead projector, fixing it to the LED panel and then lying the lcd panel from the TV across the LED lighting panel...
    Is there any reason why this would not work?
    thanks,
    Re: Overhead projector TV: Need alternative backlight source..
    I do have to ask why you are doing this?
    Such a projector will have terrible washed out contrast ratio and colour. It will also be difficult to avoid the screen door effect. If the TCPs do not die it will be the panel glass itself, if it gets too hot the LC will change properties causing colour distortion.
    If you are building your own projector, why not try using a DLP engine out of a discarded rear projection TV - that will at least achieve a decent contrast ratio and brightness, with accurate colour, whilst not dying on you.
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Hi Tom, nice to speak with you again..
      Yeah I know what you're saying.. I've thought about it myself, thinking "why bother just get a big TV" and I have a big 47 inch ambilight that I bought and fixed and another 42 inch as a spare.... But it's just something that was given to me to look at and I thought I'd try and push the concept as far as I could...
      Also, I find with even a cheap LCD 17 inch screen on the overhead projector, and accounting for screen door / poor contrast / poor definition, it actually looks really good!... That is why I'm persisting with the idea... AND I have quite a few TVs and monitors with no backlighting, so I'd like to make use of them...
      • LarrySabo
        IC Identification and source or alternative for A&O AT002318
        by LarrySabo
        This is a power regulator/driver for the CPU of an HP 15-FD0008CA that is shorted and overheats. It needs to be replaced but I can't find a datasheet nor source a replacement. My many searched have come up blank. Any help will be gratefully received....
        06-15-2024, 03:16 PM
        Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
        09-06-2024, 06:11 AM
      • Lvsitano
        Asus X532FL 3.2V at source and gate
        by Lvsitano
        I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
        First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
        I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
        First...
        06-26-2024, 02:13 PM
      • LarrySabo
        Samsung ProBook NP767XCM-K1CA battery connector replacment source?
        by LarrySabo
        Tonight I broke the battery connector on the motherboard of this laptop and need to source a replacement. See pictures. The marking seems to read B6u. The sticker on the motherboard reads TCZRFN6X00230 P03AJD BA92-20746B 06 29. If someone could suggest a proper part number and source, I would be very grateful....
        12-04-2024, 09:10 PM
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
