LG Plasma 50PC3D no VS & 1 second shutdown
  • steves7839
    • Nov 2014
    • 200
    Hello fellow DIY's. I have been searching for an analogue to the following situation:
    I've replaced swollen caps on an LG 50PC3D and had a shorted Y-SUS IPM module replaced. The TV clicks on, clicks off after 1 second. No sound or display.
    To verify the PS; with the Main and Y/ZSUS disconnected I have used resistor jumpers to force on PS and all DC voltages up to 18V are good, though about 5% low. AC_DET is solid at 5V. As soon as I force on VS_ON, the relay powers off after 1 second. I have loaded VS with a pair of auto bulbs, but DVM shows VS remains at 0V. VA properly reaches 60V before shutdown.
    I'll post a pic of the board, jumper setup, and actual measurements this evening. But I wanted to float the symptom for the collective wisdom of the community.
  • steves7839
    • Nov 2014
    • 200
    Re: LG Plasma 50PC3D no VS & 1 second shutdown
    Powered up the TV with Y-SUS connected. Green STBY LED, goes red after 1 sec. No display or sound. One anomaly- There is a connector P1001 on the unknown board located behind the lower metal shield, next to an input board. P1001 ohms 0 to GND on all three labelled pins; V5A, V12A, etc. (See photos). I don't want to connect it to the PSB if these pins are in fact shorted, unlikely tho it might be.
    Can anyone link me to a block diagram/connection diagram for this TV or identify that board?
    • steves7839
      • Nov 2014
      • 200
      I measured Q855 out of circuit and found C-B and D-B shorted. Replacement from Coppell TV is installed and I'm ready to test the PSB. However, diode checks in the vicinity show D152 reads a short, in parallel with R152. Neighboring components are Q855 and IC U151. (D152 circled in new pics)
      The schematic I have does not include this set's PSB.
      Is D152 shorted, or just looks shorted based on other components?
        I would ALWAYS replace the adjacent transistor in any power supply that has blown one transistor. This is because the failure of one transistor can damage the other even if no obvious shorts are present on the other transistor.
        • steves7839
          • Nov 2014
          • 200
          Q855 fixed it! Enjoyed it next to our 52" Samsung from 2005 for two weeks, then sold it.
          • cruiser_
            A1466 820-00165 intermittent shutdown
            by cruiser_
            hi there,
            Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
            Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
            Gives shutdown cause -128.
            Seem to work fine in SMC bypass.
            Same shutdown happens with disconnected TP/KB/KBLED/CAM.
            Observations:
            - SMC_RESET_L - when pulled down - plug goes orange/green and...
            10-11-2022, 12:06 PM
          • RATIM SIDDIQUE
            hp fpw50-la-h323p rev 1.0 automatic shutdown after 30 sec, need help
            by RATIM SIDDIQUE
            automatic shutdown after 30 sec of display coming
            do not shutdown without ramstick
            someone give me idea plz
            08-20-2024, 03:50 AM
          • howardc64
            P502UI-B1E shutdown automatically after 75s followed by power light blinking 15x
            by howardc64
            History
            - Got TV free. Prior owner claims Vizio logo shows up then nothing. He found U202 EEPROM replacement info (I know NickTV says its never EEPROM haha). Lifted 5 pads removing U202 without proper tools and thought thats end of main board. Gave the TV to me.
            - I repaired U202 pads and connections. Soldered on prior owner purchased aftermarket EEPROM (original EEPROM was tossed). TV boots to VIZIO logo, then goes blank, shutsdown after a min or so and power on light blinks a number of times.
            - Fixed 2 circa 2015 Vizios before with classical main board...
            11-28-2020, 04:25 PM
          • ArMaaN376
            Samsung PS51E550 Plasma TV
            by ArMaaN376
            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
            Opened TV cover & observed foll
            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
            How to confirm Y -Buffer board...
            06-19-2024, 04:05 AM
          • ronelex
            Acer MS2304 Shutdown when HDD or ODD Present
            by ronelex
            Model: Acer MS2304
            Board Code: 09920-2
            Issue: Unit Powers On with Display Without HDD or ODD attached
            When ODD or HDD is present unit powers on then Shutdown it reaches current of 1A that looks like want to boot but it will shutdown
            Unit wont shutdown when ODD or hdd attach if no ram is attach also
            I have tried flashing bios, the only different it will not shutdown immediately reaching 1A but eventually will shutdown also
            05-15-2021, 01:28 AM
