Vizio E371VL Dead
  • eagle00799
    • May 2012
    • 322
    Vizio E371VL Dead
    This tv is completely dead no lights at all. I read the thread by Ltank https://www.badcaps.net/forum/showth...ghlight=e371vl and I see he replaced Q0465R Resonant Power IC. (U101). I'm not sure how to test this so I was going to order one from mouser but they have 2 different ones available. Can someone tell me if either or fine or which one I should order please?
    1. http://www.mouser.com/ProductDetail/...ho3Q6J1B3f0%3d
    2.http://www.mouser.com/ProductDetail/...YtRH4kwjWFo%3d
  • eagle00799
    • May 2012
    • 322
    Re: Vizio E371VL Dead
    Anyone have an idea which one to use?
    • Iain P
      Vizio E65-F0 really dead
      by Iain P
      Hi everybody!
      I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
      So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
      I decided to check the voltages coming off the power supply they are as follows:
      connector CN201
      pin 1 (18vsb1)...
      02-23-2023, 11:32 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • catnapped
      Dead Vizio D40u-D1
      by catnapped
      Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
      04-02-2024, 08:55 AM
    • fharris1977
      Vizio D50u-D1 Dead: PSU or Main Board?
      by fharris1977
      Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
      03-12-2024, 12:22 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
