Sharp LC-52XL2E horizontal lines.
  • Badcapsluke
    • 6
    • Poland
    Hi, I've got problem with Sharp TV/LCD LC-52XL2E - horizontal lines.
    Spec. of the problem:
    -LCD panel loks is ok ( normal image whan watching analog TV - not anymore in my country)
    -stripes/lines on external sources - HDMI, component ( the lines are bit different here than on HDMI sources, but it's also different plate )
    -whan the menu is on the image is ok in places where the menu is ( Sharp ).
    Didn't changed capacitors yet, think some of them are polymer.
    Pictures below.
    Re: Sharp LC-52XL2E horizontal lines.
    Most likely main board or T-con me. I happen to have some spare parts for this model if you are interested (main board, analog board, t-con, power board)
    • Badcapsluke
      • 6
      • Poland
      Thanks for answer.. I had hope it's only some bad caps.
      I would be interested in parts to my TV. So, how can I contact you?
        I will send you a PM.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • jaco2d
          Sharp 50bj2ke horizontal lines
          by jaco2d
          This is only my seond post and so far i am very impressed with the forums.
          I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
          The small white box thing in the pics is not the tv its a reflection from the window
          Any suggestions...
          11-01-2022, 04:45 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
