Toshiba 32L502B
  • sordids999
    • May 2013
    • 2161
    Toshiba 32L502B
    https://www.youtube.com/watch?v=nW22...jPdt2RIDn6h67A
    hi guys
    ive uploaded a video to show the fault plus pictures anyone came across this fault before ?
  • sordids999
    • May 2013
    • 2161
    Re: Toshiba 32L502B
    update:
    i have checked all voltages all seem fine
    bad panel ?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5035
      • New Zealand
      Re: Toshiba 32L502B
      I can't imagine how a faulty panel could do that
      -David VanHorn
        Re: Toshiba 32L502B
        It does look like a possible failed panel. An on/off pattern like that has sometimes been seen. LVDS cable OK? Tried a factory reset using Menu 4-7-2-5?
        • sordids999
          • May 2013
          • 2161
          Re: Toshiba 32L502B
          yes tom checked lvds cable re-seated also done Menu 4-7-2-5 reset done but still this on each menu
          https://www.youtube.com/watch?v=6HhG...jPdt2RIDn6h67A
            Re: Toshiba 32L502B
            Maybe try a small bit of freezer spray on T-con and the main board?
            • sordids999
              • May 2013
              • 2161
              Re: Toshiba 32L502B
              i have tried heating up the tcon and main board with hairdryer ill try the other way now
                Re: Toshiba 32L502B
                I had a non-intermittent issue similar to yours caused by a failed diode on the T-con board. TV has worked for my sister for over a year after this repair:
                https://www.badcaps.net/forum/showthread.php?t=33134
                • sordids999
                  • May 2013
                  • 2161
                  Re: Toshiba 32L502B
                  ok ill try the freeze spray i have also noticed that on some test points on the tcon board the voltages are not stable but all others on psu,main are fine could this be tcon related then ?
                    Re: Toshiba 32L502B
                    Yes it's possible, ones to watch out for are VGH and VGL (maybe VONE and VOFFE on some boards)
                    • sordids999
                      • May 2013
                      • 2161
                      Re: Toshiba 32L502B
                      VGH is staying steading at 26.5 volts
                      its the other test points i have shown in the uploaded picture that are not staying steady,when the picture distorts the voltages drop
                      • sordids999
                        • May 2013
                        • 2161
                        Re: Toshiba 32L502B
                        hello
                        i thought ill go back to the tv today but upon turning on the tv i now have nothing totally dead but the touchpad still beeps,i still have 24 volts to invertor and voltages going to the main board
                        any ideas ?
                          Re: Toshiba 32L502B
                          Can you try unplugging one panel ribbon at a time and seeing if the voltages do the same and if the screen flickers?
                          • sordids999
                            • May 2013
                            • 2161
                            Re: Toshiba 32L502B
                            i cant do nothing now tom today the backlight wont even come on to test
                            it seems something is wrong the tv wont even boot up
                              Re: Toshiba 32L502B
                              Well, it is a Vestel...
                              • sordids999
                                • May 2013
                                • 2161
                                Re: Toshiba 32L502B
                                yes agreed and frustrating i was going to try the freeze test on the main board and tcon then i thought oh great when it wont even boot up today
                                  Re: Toshiba 32L502B
                                  Try isolating T-con from main board. Whatever may be failing on T-con or panel may have shorted altogether. See if you get a backlight.
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    Re: Toshiba 32L502B
                                    tried that already nothing
                                      Re: Toshiba 32L502B
                                      Does the standby indicator light up?
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        Re: Toshiba 32L502B
                                        ive also noticed today that U5 in the picture attached is getting really hot !
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
