VESTEL 17PW25-4 SOME CAP VALUES Needed
  • zomi
    • Nov 2011
    • 509
    Just need some cap values as my niece has mixed up my caps and thrown away my notes
    on the 17pw25-4 250111 v1
    I have looked at the schematics but the caps I have seem to slightly different
    what I need is
    c960
    c950
    c971
    c972
    can some look on thier board and let us know..
    Re: VESTEL 17PW25-4 SOME CAP VALUES Needed
    There are maybe 50 different versions of this power supply...... so no one board can be compared
    As a guide:-
    For 24~26" LED backlit: 24V rail has 3300uF x 1
    For 26~32" CCFL backlit: 24V rail has 3300uF x 3 + 1000uF x 1
    For 42" LED backlit: 24V rail has 3300uF x 3
    • popeye
      • May 2011
      • 155
      Zomi
      Replace the caps you have on the pcb with the same spesification
      • zomi
        • Nov 2011
        • 509
        i resolved it
        With some help from google and cross ref from the schematics.
        Moral: keep kids away from work areas, no matter how cute they are
          Out of interest... this board had bad capacitors? I have not encountered that on a 17PW25-4 yet myself. It does use garbage caps so that wouldn't entirely be a surprise...
          • zomi
            • Nov 2011
            • 509
            I had a board where the main big cap had buldged and gone bad.
            Ended up decapping most of the board checking the caps.
            Had a couple of blown diodes
            Replaced diodes and cap (main one)
            and then put back together and tried it
            was still dead, checked a few more things and nothing..
            so in the end called time..
            Have to know when to call time and move on esp on these vestel pieces of crap.
            New resolution is to try not to get sucked into any more vestel nasties..
              This power board usually blows stuff on the primary when diodes go bad. It is a complete and utter piece of shit. I have repaired four of them so far with the same fault. Avoid where possible.
              • proxneo
                Recapping Sony ICF-SW55 - verifying cap values
                by proxneo
                Dear reader
                I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                At the moment, I have selected replacements based on the following list of values:
                3 x 470uF 10VDC
                3 x 4.7uF 35VDC
                4 x 47uF 50VDC
                8 x 22uF 6.3 VDC
                1 x 220uF 6.3VDC
                5 x 100uF 6.3VDC
                Which...
                06-21-2023, 12:38 AM
              • ongobongo
                Surface go 2/3 - resistor values needed
                by ongobongo
                I have a surface go 2/3 here which has problems with the battery showing/charging.
                I played around with the resistors on the back of the battery connector but forgot to take good measurements beforehand.
                can anyone help with the correct values of the attached resistors?
                thanks ongo...
                06-12-2024, 03:20 PM
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
              • l3emarsh
                Panasonc/vestel 55" 4K HDR Hardware/Software profile needed
                by l3emarsh
                I have a Panasonc/vestel 55" 4K HDR TV and I need Hardware/Software profile with the alexa option and satalite option as I have upgraded my cpu main board.
                If anyone has a copy of the hardware I need PLEASE send me the copy.
                I can upgrade to Alexa option and Satalite option using Vestel Toolbox v1.1 so that's not essential.
                Greatfull for any help.
                Thank you.
                Lee.
                01-08-2022, 07:43 AM
              • mariukonie
                Induction hob PCB VESTEL 20fr25 from cooker Rangemaster propl60eibl help needed.
                by mariukonie
                Hi. Could anyone with knowledge advise if this pcb in photos can be repaired? I'm willing to spend time and money on it to gain experience however I searched net for schematics and couldn't find so it's impossible to know what are some of burnt components. I can't find any second hand replacement board and new one is out of my budget and it exceeds value of cooker. I'm new to this forum but have had few successful pcb repairs of tv's and cooker pcbs and also made few working circuits for fun. Any help appreciated. Regards....
                08-23-2023, 08:19 AM
