LG 50PG20 plasma thin line going across screen
  • zell66
    • Nov 2014
    • 35
    • usa
    I have a LG 50PG20 tv, I just replaced the power supply board and got tv to turn on, but now there is a very thin (about 1/16") going across tv screen. Any ideas on what this is and how to fix it?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PG20 plasma thin line going across screen
    Did you happen to take the ribbon cables off the buffer boards? Maybe try reseating the offending cable.
    • zell66
      • Nov 2014
      • 35
      • usa
      yes I removed all ribbon cables from power supply board. That could have an issue with one thin line across tv???
      • freakaftr8
        • Oct 2012
        • 3743
        No I meant the ribbons that go into the panel directly. They are copper colored. On the far left.
        • zell66
          • Nov 2014
          • 35
          • usa
          no i did not, but i can check them in the morning.
            Is the line going from left to right or top to bottom?
            • zell66
              • Nov 2014
              • 35
              • usa
              tom66 it is going from side to side about 6"from the top
                It could be a bad plasma panel. There is a small chance it is a Y-buffer fault but that is very rare.
                • zell66
                  • Nov 2014
                  • 35
                  • usa
                  tomm is it fixable or is it just the way it will be?
                  • zell66
                    • Nov 2014
                    • 35
                    • usa
                    sry tom66 is this line thing fixable or just have to live with it?
                      Most likely it will not be fixable.
                      • zell66
                        • Nov 2014
                        • 35
                        • usa
                        ok thanks for the info.
                        • Ted29946
                          LG 50PG20-ua Plasma TV repair help
                          by Ted29946
                          I'm new to this so I hope I'm doing it right So....I picked up a LG 50PG20-ua Plasma TV (Someone's throwaway pickup) First power up no picture or sound
                          Found power board to be bad and I repaired it. (Bad caps) Now all power volt readings are good. Still no picture or sound. I plugged in power cord, no click and the standby light on the on/off button comes on blue as soon as it is plugged in and does not turn off when button is push. I then pulled the main board off to look at it better and the initial inspection (front and back) I cannot see anything bad. Before I put the board back
                          10-24-2024, 11:12 AM
                        • bffargo
                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                          by bffargo
                          LG 60PB66550 NOV 2014
                          PSU: EAY63168603
                          PCB: EAX65359531 2013.11.01 Rev:1.0
                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                          Symptom:
                          While watching, just went black and started clicking relay every few seconds.
                          Initial diagnosis:
                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                          Deeper diagnosis:
                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                          09-09-2022, 07:34 PM
                        • cubytus
                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                          by cubytus
                          Hi to all,
                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                          01-10-2024, 01:26 AM
                        • canadaboy25
                          LG 50PG10 Plasma Vertical Line
                          by canadaboy25
                          Hey guys, I'm being offered an LG 50PG10 plasma with a vertical line running down the screen.
                          Apparently, if you give the TV a good smack on the frame above the line, it will go away for a while.
                          Does this sound like a bad solder joint or loose ribbon cable? Or a bad panel? If it's not likely to be a bad panel I will likely pick it up.
                          What do you guys think?
                          Thanks...
                          11-24-2020, 11:50 AM
                        • otaku_nut
                          Vizio E701i-A3 fixed but now has red vertical line
                          by otaku_nut
                          Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                          08-19-2025, 06:11 PM
