Washed out picture .. scan rate does not recover fast enough .. slow .. I checked all the voltages .. IE : - zbias (100) vsc (115 , VY (200) and VA ( 60) .. they all are in working order .. I was thinking, based on past post on this board , that the Z board on the right side while looking from the rear into the plasma set was at fault .. before I go and order that board is there anything else I should check. THe Y board's fuses are all ok as well. Thank you in advance for your input
