Wharfdale 32" TV dead but fuse ok (Vestel PSU)
  • mikcatta
    • Nov 2014
    • 7
    Hi
    Given a dead one of these to play with and it has a Vestel 17pw15-9 PSU in it. With all the connections unplugged I could see 24v, which fades away to nothing when I plug back in the cable to the main board.
    I can see there is a repair kit that covers stuck in standby, but I wanted to be a little more sure of the fault before ordering.
    The 5v reg tests good, even with 120ohm resistor as the load. The two main culprit capacitors read as 15nf or thereabouts.
    Checked the electroytic caps with the Peak and nothing with a high ESR.
    Other threads suggested bringing the PSU out of standby, but not too sure how that happens.
    Any suggestions what to check next?
    Rgds
    Mike
  • mikcatta
    • Nov 2014
    • 7
    Re: Wharfdale 32" TV dead but fuse ok (Vestel PSU)
    Having soldered back in the 5v reg and caps the TV has come back to life! Hooray
    • dellxps15
      macbook a1707 15 inch trackpad dead. blown fuse identification
      by dellxps15
      hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
      another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
      04-30-2024, 10:48 AM
    • Acnologia
      Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
      by Acnologia
      Here is a pretty crazy one.
      Step 1.
      Laptop was brought to me as dead not working. Removed everything , cleared everything.
      Step 2.
      Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
      Step 3.
      Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
      Step 4.
      Lets ,dive into the board. I see the edp cable on the...
      05-07-2025, 07:16 AM
    • Pwtzz
      Samsung 55NU6900 - Heard a pop then tv is dead, burnt cap & dead fuse
      by Pwtzz
      Hi All,
      Before replacing what I know to be bad even with my novice experience. What I have checked at the moment is the fuse and the obvious burnt capacitor. I haven't bought any replacement parts yet.
      I still have no idea how this happened but could just be plain old turned bad. What other stuff should I consider buying as replacement? thanks in advance.
      Edit: I saw that a replacement board can be had for about $50. I would rather attempt to fix before just replacement the board.
      07-19-2022, 06:45 PM
    • jesterace
      Samsung UE46ES8000 Blown fuse but no other signs of short
      by jesterace
      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
      09-11-2024, 03:14 PM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
