Samsung LE37A558P3F
  • viduka
    • Mar 2014
    • 64
    • Scotland
    Samsung LE37A558P3F
    Hi
    I've got a Samsung LE37A558P3F it had standard Samsung Solarized Picture due to a faulty T-Con. I had this repaired but now after it has been running for a few minutes it keeps searching for signal on all inputs. Example : Will just randomly come up HDMI 1 searching for signal then display the image again. This just gets worse the longer it's left until is only displays the picture for a few seconds before resetting.
    As usual any help would be great.
    09-07-2024, 05:50 AM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • Mgiffune
    by Mgiffune
    I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
    I ordered a supposedly β€˜new' Tcon board this time, and
    06-09-2024, 10:28 AM
  • YellowJacket
    Samsung QE55Q60RAT - no picture
    by YellowJacket
    Hi friends,
    a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
    07-30-2024, 01:31 PM
