Panasonic plasma w/ odd ghosting from previous images
  • gengler
    • Nov 2014
    • 5
    • US
    I have a TC-P55VT30 that's having some odd display issues. I've searched the forums and have found somewhat similar issues, but they seem quite the same. Of course, its always a matter of what to search for...
    Here's what's going on. I'm seeing faint images of things that were on the display previously in various situations. Its not burn-in because they're images that were only on the screen for <30seconds.
    For instance, I started up the TV cold and went into the setting menu. I was poking around for a minute or two. I then got out of the menu, switched to the AppleTV input and turned on the AppleTV. On the menu display which has a dark gray/black background, the top of the screen was flashing somewhat brighter and I could see ghost images of "Viera Link" from the settings menu.
    In another case, while watching, there was a bright screen and, in the top half, I saw (in cyan-ish color) the image of the Netflix episode guide that I'd had stepped through about 10 minutes before. I wasn't only on that screen for <10s. So, again, I wouldn't think it to be burn in.
    Otherwise, the TV's works fine. There's no LED blinking at startup or anything. But, just to be safe, I've stopped watching (based on what I've read on other threads) it and disconnected it from power.
    Any help would be appreciated.
  • KevinCro
    • May 2014
    • 104
    Re: Panasonic plasma w/ odd ghosting from previous images
    I'm not an expert, but I have read elsewhere that this can be caused by the z sustain board. I would check it for blown capacitors or other visibly bad components.
      This is completely normal for 2011 Panasonic sets. You could consider it a fault but it's just due to how Panasonic drive the panel. To get low black levels, they do not apply such a wide reset pulse, so you can get ghosting on black.
      • tw2005
        • Oct 2011
        • 6458
        I get that effect on my 2010 too sometimes on a straight black screen after a still image.
        Does not affect the Tvs performance or image, looks weird, but I don't worry too much. I have no burn and panel has 10300hrs on it now. Image still very good.
        • gengler
          • Nov 2014
          • 5
          • US
          I guess the issue that worries me most are the "cyan-ish" discoloration in bright scenes. It's definitely something new that i just started seeing a week ago. Is that normal with age too? It's really quite noticeable.
            No, that could be a serious fault. I did not realise you had that fault.
            You should unplug the TV immediately. The screws on the SC board can arc due to loose connections, this can cause damage to the SC board and SU/SD buffers.
            The fix is to replace the screws with the proper type.
            • gengler
              • Nov 2014
              • 5
              • US
              Thanks for the help. The tv will remain unplugged and I have the replacement screws on order.
              • gengler
                • Nov 2014
                • 5
                • US
                I just wanted to say thank you for the advice. The screws are replaced and the TV working as it did before.
                  Glad to hear - Seems to be a common issue!
                  • jm1234
                    Panasonic plasma TX-P42ST50 - 6 blinks
                    by jm1234
                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                    I checked that board for any obvious faults...
                    05-22-2024, 06:59 AM
                  • stecos
                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                    by stecos
                    Hi everyone!
                    I happened several times, in the search for help from the web, to consult this very interesting forum.
                    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                    Having said that I come to the gist of my post on the forum as the title suggests.
                    For my passion for technology I'm now collecting several...
                    11-28-2022, 11:39 AM
                  • cloo
                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                    by cloo
                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                    After doing a factory reset this problem was gone and the picture was back to...
                    01-06-2025, 06:02 AM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • Lintesir
                    Panasonic P42S30 Plasma - Pink sparkles
                    by Lintesir
                    My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                    There is about a 5cm high region at the top without any sparkles,...
                    07-26-2024, 03:16 AM
