SAMSUNG led un32eh4003f Plays melody No picture & led blink
    Re: SAMSUNG led un32eh4003f Plays melody No picture & led blink
    "1 - 211v - D+
    2 - 189v - S-
    3 - 0v - N/C
    4 - 191v - S+
    5 - 0v - D-"
    One thing that is bugging me is that looking at the bottom side of the board, pin 2 is connected directly to pin 4, so the reading on pin 2 and pin 4 should be the same unless the trace I see in the picture is not what it is on the board.
    But any way I traced out the board and draw up simplifed circuit.
    You are getting 0V on pin 5 which cannot be normal, it should show Voltage there on pin 5 if the LED strings are not open.
    Pin 5 is the return line through the PWM controlled Power MOSFET (Q9803) and the current sensing resistor (R9803) for maintaining constant current through the LED strings.
    • mangus580
      • Mar 2012
      • 18
      • US
      So that would suggest an open LED circuit, correct?
        Yes, and I want to verify for sure that I am correct by testing each one to find out.
        • mangus580
          • Mar 2012
          • 18
          • US
          Ok, I dont have an easy method for testing each LED. I am not even sure how easy it is to get to each individual LED.
          Talking with a friend of mine today telling him of my project.... He suggested I try using an ammeter from D+ to D-
          He said this should show me a constant current essentially replacing the LED strips as far as the power supply is concerned.
          So... I tried that. I got a flicker on the meter briefly, but it went back to 0.
          Using his concept, it would say the power supply is the issue...
          Thoughts?
          In the end, I am sure we can agree, that its either the power supply or the LED strips. Since replacing both keeps me under my budget for fixing the TV, I am not opposed to replacing both.... But I would prefer to make a well educated guess as to which is needed.
          Thanks again,
          Mike
            Using amp meter like this?
            https://www.badcaps.net/forum/showpo...4&postcount=95
            Or using indicator:
            https://www.badcaps.net/forum/showpo...&postcount=107
            If the bad LED is not completely open but has high resistance then you may see very little current flowing through the string but not enough to light up the LEDs.
            I would get the strips first and see what happen.
            • mangus580
              • Mar 2012
              • 18
              • US
              #26
              I ordered the LED strips - and they should arrive tomorrow - I will update you with what I find...
              • mangus580
                • Mar 2012
                • 18
                • US
                #27
                All better!!!!!
                Thanks!!!
                  Good to hear, shame to see yet another set taken down by bad LEDs though.
                    Thanks for the follow-up, BTW, how did you get the part so fast?
                    • mangus580
                      • Mar 2012
                      • 18
                      • US
                      #30
                      I paid the extra $4 for 2 day shipping.... I figured it was worth it to not have the tv apart in my office any longer than needed.
                      Tom, I was smart, I am keeping the old strips too. I am figuring only one strip was bad, and if it happens again, its likely to only be one... guessing maybe I can swap strips around to find the good ones at a future date if needed!
                      • Caleb
                        Smokin IC's
                        • Feb 2013
                        • 645
                        I just got one of these today, on my bottom led strip are 3 dead and the top wont light at all, Has anyone had any success pulling leds from another dead board and replacing them? I dont have any other samsung led panels but Ive got a bunch of other led strips from broken screen sets. May just end up trying to Frankenstein another backlight into the panel, I looked around online and the only ones in stock would cost 60$ plus shipping.
                        Liberating magic smoke one part at a time
                        • mangus580
                          • Mar 2012
                          • 18
                          • US
                          #32
                          These are the LED's I used:
                          http://www.shopjimmy.com/samsung-cy-...s-2-strips.htm
                          worth every penny! the tv has worked awesome ever since.
                          • Caleb
                            Smokin IC's
                            • Feb 2013
                            • 645
                            If only they had them in stock.....they have set a fair price. Everyone else has set a rather high price point. I have several sets with leds that look identical. Not sure if they would be compatible or not. Pulled a set from a 32 insignia tonight to check and see if I can pull individual LEDs. The lenses appear to be glued on top of the diodes. Does master Budm have any suggestions for removing them without destroying them?
                            • mangus580
                              • Mar 2012
                              • 18
                              • US
                              #34
                              You could try contacting shop-jimmy to see when they estimate stock returning....
                              I kept my old strips - not knowing if one strip is still good.
                              • thoma
                                • Sep 2012
                                • 268
                                http://www.ebay.com/bhp/led-backlight-strip
                                Here are a lot of LED Stripes for Backlightning LCD TV
                                • lordkev
                                  • Jun 2015
                                  • 7
                                  • St Kitts
                                  #36
                                  How did you guys actually get at the LED strips? I have a similar model UN40H5203AF and I could see them if I took off the front bezel and separated the panel. However, I imagine I'd want to go in from the back somehow to replace them?
                                  • Caleb
                                    Smokin IC's
                                    • Feb 2013
                                    • 645
                                    You have to completely dismantle the panel, they are under the glass and the diffuser. Both of which will show dust and dirt if you get them dirty, the glass is very thin and the ribbons fragile, this tv has no screws just a bunch of clips. Work your way slowly around the bezel popping the clips loose with your fingernail. Then gently remove the glass and diffuser then you can finally access the led string. It would have made them way too easy to replace if they had placed them in from the back.
                                    • keithwyatt533
                                      • Jun 2015
                                      • 5
                                      I have the same model and I've checked all of the LED's and they are on but don't seem very bright. I can see the picture but it is very dark and I can't make it any brighter with the brightness/contrast/etc adjustments. What should the voltage be on pins 1/2 and 4/5? I get 22.4 V on each set with pin1 to chassis - 152V, Pin 2 - 129V, pin 4 - 129V and pin 5 - 107V. Any help would be appreciated.
                                        How about the BACKLIGHTS LEVEL adjustment, it is not the same as the brightnees adjustment.
                                        http://downloadcenter.samsung.com/co...0526105716962/[UE4003-ZA]BN68-04459A-02ENG-1014.pdf
                                        • keithwyatt533
                                          • Jun 2015
                                          • 5
                                          Adjusting the backlight also has no effect.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
