Samsung LE40M87BD blinks 6x then starts normal ?
  • zomi
    • Nov 2011
    • 512
    Samsung LE40M87BD
    Had the click issue
    Recapped the main caps.
    Fitted ne epprom
    Still had issues
    then went over some solder joints on the psu.
    Now it seems to work..
    Just blinks 6 times then turns on
    IS the blinking normal ?
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung LE40M87BD blinks 6x then starts normal ?
    I would think so but I don't have that set. I have seen other Sammies that blink before the backlight comes up and they worked fine.
    • Shinju
      • Mar 2014
      • 1239
      Normal operation! Some sammies boot up slower then others!
      • Dang
        • Aug 2013
        • 440
        Yep, agreed with the above, all perfectly normal. I've seen some Sams take 4 flashes, others 6 or 7 flashes, just the way it is.
          Note that Samsung does not use error codes on the power light - so the number of flashes would never mean anything anyway. I agree with everyone above, completely normal.
          • zomi
            • Nov 2011
            • 512
            Thanks for that guys
            Just wasn't sure
              09-07-2024, 05:50 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
