Samsung PN50A550S1F does not turn on, relay clicks.
  • EsqzMe
    • Sep 2013
    • 56
    Well...I'm BACK !!!!!.
    After I installed the new power board last October (a YEAR ago !! See prior thread) and had a functioning TV again, I parked this TV in my bonus room and didn't use it.
    I had already bought a new one, so this was a spare for future home expansion. 2 days ago I moved it into the remodeled master bedroom and turned it on for the first time since last year. Everything was great.....until last night when it made a couple of pop sounds and went blank. Turned it off and back on and life was good for about 15 minutes and then blank screen, relay clicking....just like the original problem!!!
    OK, I've gone back into it......here's where I am at now. Unplug Main from PS and power does not come on at all. Unplug any other board and no change, clicking relay.
    Installed 270 ohm resistors on Power to Logic connector PS-ON to Gnd and Vs-on to 5.3v. Jumped test pins 3 and 4 on Logic board.
    With Main unplugged I get no power. With Main plugged in I get 55 volts on Va and 204 volts on Vs. The screen does test colors starting White then Green then Red, but then the relay will click off and back on and the cycle starts over again.
    By the way, I also replaced the Y-Main with a new one I had purchased just in case my poor solder job on the replacement cap last time was at fault. No change.
    So......what do you suggest? I don't think my new Power Supply is the culprit, unless it has been killed by some other fault. Is it the main ?
    I read somewhere else about a cap at C102 on the underside of the Main being a common culprit?? I have ordered a couple (inexpensive), should be here Friday, so I can install this weekend and see.
    Any other advice???
    Wonder what this thingy on the circuit board does??
  • EsqzMe
    • Sep 2013
    • 56
    Re: Samsung PN50A550S1F does not turn on, relay clicks.
    Hey....replaced C102 on main board......so far so good. $1.42 plus mail cost.
    I'll leave it on for a while and see if that was the final fix.
    This forum is great if you take time to search and read....
    • EsqzMe
      • Sep 2013
      • 56
      Success. Burn in for 20 hours.....she passed the smoke test! Thanks for the great help on this forum!
      • aaronwt6
        • Apr 2013
        • 855
        • US
        Sorry to dig up an old thread but I was wondering if you could tell me where you found the cap to replace this? I have at least 3 of these boards in need of repair but cannot locate the caps.
        Thanks in advance,
        Aaron
        • EsqzMe
          • Sep 2013
          • 56
          Digi-Key Corp. www.digikey.com
          Their item number # P2016230CT-ND
          CAP TANT 47UF 10V 20%. 1411
          And my tv is still going strong!
            09-07-2024, 05:50 AM
            Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
            by momaka
            I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
            Problem:
            Backlight cycles On and Off.
            Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
            01-17-2019, 11:23 PM
          • Journey11
            Samsung TV won't turn on ... keeps cycling the power relay on & off
            by Journey11
            Hi All,
            First time posting here ... my name is Kevin but my friends call me Journey.
            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
            07-04-2024, 02:44 PM
            09-06-2024, 11:40 PM
