Panasonic P42G20ES
  • Mtgtnt
    • Nov 2014
    • 18
    • Slovakia
    Panasonic P42G20ES
    Hello everyone.
    Family members Plasma decided to stop working and they took it to a technician that told them it would be 400 Euro to repair. I told them I will look at it even though I haven't done any electronic work in 20 years I still figured I can grab the service manual and look up the code the power light was giving.
    Now before I start replacing boards (not going to test mosfets and caps) I did a lot of reading here and through the manual. Here is my findings:
    When turning it on, I get the relay clicks as normal and the green light flashes.
    The green light turns off and the red light starts blinking.
    4 blinks.
    Disconnect P2: 7 blinks.
    Disconnect P11: 4 blinks.
    Disconnect P35: 4 blinks.
    Disconnect P6: 10 blinks.
    I did not disconnect more than one at a time.
    Is there anything else I should check to be sure its only the P-board? Is there any tips in how to test for any of the other boards be faulty also?
    Thanks for everyone's time reading my request.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic P42G20ES
    Blown SC board, there's a cheap board in Europe assuming it's ok.
    • tw2005
      • Oct 2011
      • 6458
      All going well ,should fix this for 15% of what you were quoted. The SC can be repaired so you may want t keep it and have a go, use the good board as a template.
      It's not a P board fault(not normally)
      • tw2005
        • Oct 2011
        • 6458
        ........When turning it on, I get the relay clicks as normal and the green light flashes.
        4 blinks. PSU SOS, PSU has dead short from SC board
        Disconnect P2: 7 blinks. Vsus line to SC2(SC board TNPA5081AH), change of status because shorted Vsus removed
        Disconnect P11: 4 blinks.Vsus to SS board, but Vsus is still shorted at SC, hence no change
        Disconnect P35: 4 blinks.Vsus is still shorted at SC, hence no change
        Disconnect P6: 10 blinks.missing voltages so A board produces 10 blink....................................................
        • Mtgtnt
          • Nov 2014
          • 18
          • Slovakia
          removed....
          • tw2005
            • Oct 2011
            • 6458
            Part numbers you can search are, TXNSC11NEK42 , TNPA5081AH & TXNSC1LGUU.
            Also search TNPA5081 in badcaps and I have a fair bit of info based on the 50" model Sc board.
            • Mtgtnt
              • Nov 2014
              • 18
              • Slovakia
              Great! Part paid for and on its way.
              How do I go about doing a resistance test on the P-board?
              Been a long time since I did this and all I have is a multi-meter.
              • tw2005
                • Oct 2011
                • 6458
                P board should be fine, the buffer board needs checking to safeguard blowing another Sc just in case it failed too which can happen. I'll have a look because these have a SM (Sd/Su combined). Quick test is to put the meter in diode mode and place one probe on the earth plate on the buffer board and then slowly run the other along the face of each contact pin at the buffer output ribbons. You do not want to see any dead shorts.
                There is a 3 point resistance test i do which is covered in a training guide i like for my 50" which we should be able to use or maybe the S2/S20 series which ahs the same buffer but smaller Sc boards.
                • tw2005
                  • Oct 2011
                  • 6458
                  slide 90, has Sm board test
                  your TV
                  • tw2005
                    • Oct 2011
                    • 6458
                    This is for the G20/25 series, i have not checked if this has SM tests but better fault finding in this as is mentions SC as a probable and most likely cause for 4 blink.
                    https://www.badcaps.net/forum/attach...6&d=1383456126
                    Slide 43 you could use the pinouts on the buffer boards for the same test, they have a third checkpoint compared to 2 in the other guide,
                    post up your results for us to see.
                    • Mtgtnt
                      • Nov 2014
                      • 18
                      • Slovakia
                      Perfect. As soon as I have all these tests done, I will post the results. May take me a little while as its lunch time and have to deal with making lunch for family. (National Holiday today)
                      • tw2005
                        • Oct 2011
                        • 6458
                        Lucky you. I am curious, how is your english so good?
                        • Mtgtnt
                          • Nov 2014
                          • 18
                          • Slovakia
                          I am an expat from US. Been here since Feb 2006.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Fair enough, it's funny the people you get to chat with. That explains everything, just had me curious talking to someone with perfect english in Slovakia
                            • Mtgtnt
                              • Nov 2014
                              • 18
                              • Slovakia
                              I have tested the SM board pins 1 and 5.
                              My meter only has 2M-Ohm check so not possible to see the 4M-Ohm resistance.
                              When testing Pin 1, reading started around 900K and moved past the 2M limit in less then 2 seconds.
                              When testing Pin 5, reading started around 200K and moved past the 2M limit but at a slower rate. It took around 5 seconds.
                              I did a second test but both read Open right away so I let it sit for a few minutes before testing again. Results were exactly the same.
                              Also to note that my battery light came on shortly after my first test. I will pick a new battery up tomorrow and to the test again just to make sure.
                              • tw2005
                                • Oct 2011
                                • 6458
                                You know I've seen this before but the info in the S2 series SM test is incorrect.
                                Pin 1 4Meg could be correct but Pin 5 , 190K for 5V_F is incorrect. probably why your meter went out of range. If you cross reference to the other G20/25 series 5V_F is over 5 meg
                                Test pin 2 and I would expect 220k
                                Then go to connector SM41
                                Test
                                Pin 2 VFO expect over 2 meg (4meg)out of range
                                Pin 4 VSCN-F expect 220k
                                Pin 8 5V_F expect out of range over 2 meg (5.7Meg)
                                  I think it's also worth testing for shorts from each of VFO/VFG to the output pins.
                                  I've had a buffer board (in an LG) with no shorts between the equivalent of VFO/VFG, but it had a short between VFO and the top most output pin.
                                  It was pulling down Vsc supply, lucky no damage to Y-sus, but on a Panasonic, it can damage the SC.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Have not struck that yet with these, but all for being thorough
                                    • Mtgtnt
                                      • Nov 2014
                                      • 18
                                      • Slovakia
                                      I have finished testing all pins of SM41/42/46. All were out of range except SM41 pin 4 and SM42 pin 2. Those were exactly 220k.
                                      Some took a while to go out of range, while most were oor right away.
                                      http://youtu.be/NQtSXVgTUIg
                                        Does your meter have a beep function where it will make a sound when the probes touch?
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • mecha1166
                                          XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                          by mecha1166
                                          I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                          07-01-2024, 05:47 PM
