VIZIO - P50HDTV10A dont turn on PSB has power
  • stormyt
    • Nov 2014
    • 5
    • usa
    Ok I searched the forum and did not get any where. i am a nocice but a quick learner learning to do component repair.
    When the tv is plugged in the relay clicks.
    hit power button the front light turns green. then it flashes 10 orange blinks.
    the PSB pis all read proper voltage so i have narrowed that out.
    The 2 voltages to the y-sus are within in tolerance of the sticker.
    I unplug all cables excpt the standby and it makes no diffrence, which makes me think it may be the PSB.
    Any directions to go from here?
    thanks for the group.
  • stormyt
    • Nov 2014
    • 5
    • usa
    Re: VIZIO - P50HDTV10A dont turn on PSB has power
    PS
    fuses all test good
    VS ect, voltage raises and lowers upon clicking power button
    all heat sinks are cool
    • Ltank
      • Jun 2013
      • 776
      What is the voltage across the main filter caps? Should be about 380vdc. If it's 170 the PFC circuit is keeping it shut off.
      Are you getting Standby voltage 3.3 or 5vdc? Does the mainboard send a PS-ON command to P.S. telling it to turn on?
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
        09-06-2024, 05:59 AM
      • Journey11
        Samsung TV won't turn on ... keeps cycling the power relay on & off
        by Journey11
        Hi All,
        First time posting here ... my name is Kevin but my friends call me Journey.
        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
        07-04-2024, 02:44 PM
