LG 50PJ350 plasma clicking on and off.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i have a LG 50PJ350 and when you switch on the screen flashes and tv turns off but then trys to switch on again and does same thing before shutting itself off to standby. I have done a bit of research on google and found a page for PSU EAY60968701 and same problem is told to replace 1 fuse (F302), 1 diode (D304), the power resistors as shown on the pictures (R927 and*R929 for the board revisions*with two resistrs) and the IC301 voltage regulator IC.
    Can anyone get me a scematic or tell me which parts i can buy as i am unsure.
  • sordids999
    • May 2013
    • 2156
    • uk
    Re: LG 50PJ350 plasma clicking on and off.
    http://www.ebay.co.uk/itm/EAY6096870...item3f373dcc48
    found this for you
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      Thanks Sordids999. Will buy that and give it a try cheers
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        @Sordids999 ordered that kit and swapped out components, now fully working. thanks for the help.
        • bffargo
          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
          by bffargo
          LG 60PB66550 NOV 2014
          PSU: EAY63168603
          PCB: EAX65359531 2013.11.01 Rev:1.0
          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
          Symptom:
          While watching, just went black and started clicking relay every few seconds.
          Initial diagnosis:
          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
          Deeper diagnosis:
          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
          09-09-2022, 07:34 PM
        • B0r1s
          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
          by B0r1s
          PSU - BN44-00878A
          Symptoms:
          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
          A weak clicking sound was coming from the transformer.
          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
          Progress:
          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
          01-17-2023, 04:58 PM
        • novak2
          Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
          by novak2
          Hello there,
          I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
          The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
          From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
          Thanks in advance.
          09-25-2020, 02:34 PM
        • Keshenatech1
          LG 50PJ350 plasma blowing Y-Sustain board
          by Keshenatech1
          Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
          05-13-2020, 10:08 AM
        • slimmy182
          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
          by slimmy182
          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
          Looking on google I found this:...
          01-14-2023, 11:55 AM
