LG 42LY95-ZA Power problem.
  • PlusCom
    • May 2013
    • 50
    • Greece
    PSU – EAY3273110
    Mainboard – EAX36680401 (3)
    Have this TV that my friend gave me. It goes from red standby led to green but no screen no sound. I have 5v standby and pwr-on 2v but power supply doesn't turns on. My friend had replaced PSU with used one from ebay one but TV does same exact thing so I'm not sure if that PSU is also bad or the problem is on mainboard. The weird thing is that sometimes it turns on normally and can work from 5 min to whole day and before it stops screen starts flickering and you can hear something like clicking sound which I believe comes where the 2 transformers is. Also when screen flickers you can hear a loud static sound from the speakers. I'll try to take a video later because it's difficult to explain. If someone has any idea what can it be please help.
    Readings when TV works fine.
    P201 ON OFF
    ACD 5.08 5.09
    PRR-ON 2.10 0.04
    5Vs 5.08 5.12
    I-C 3.95 0.01
    ERR 5.02 0.00
    BRI 0.02 0.00
    5Vs 5.08 5.11
    DIM 0.03 0.00
    6V 6.03 0.12
    3.4V 1.06 0.02
    P202 ON
    19V 18.51
    6V 6.08
    3.4V 3.48
    12V 11.76
    P204 ON
    24V 24.00
    BRI 0.02
    I-C 3.95
    DIM 0.03
    ERR 5.02
  • FIXITNOW
    • Jun 2008
    • 128
    Re: LG 42LY95-ZA Power problem.
    check ic901 . Its a 3.3 volt regulator on main board
    also check caps in this circuit C970 and c920 can also cause problems,
    also check the esr of all the 100uf on top right of main board.
    • PlusCom
      • May 2013
      • 50
      • Greece
      Update
      Finally TV stoped working.Here's the readings with green led but black screen.
      p201
      ACD 5.08
      PRR-ON 2.00
      5Vs 5.08 5.12
      I-C 3.59
      ERR 0.09
      BRI 0.78
      5Vs 5.08
      DIM jumps from 2.48 to 3.28
      6V 0.55
      3.4V 1.06
      P202 ON
      19V 0.00
      6V 0.55
      3.4V 3.49
      12V 0.17
      • PlusCom
        • May 2013
        • 50
        • Greece
        Thanks mate for your answer.
        ic901 looks fine. pin1=0 pin2=3.3 pin3=5
        There is no C920, I will check the rest of the caps later.
        • hugocarmo
          Panasonic TX-24A1UN CRT Sound and Input problem.
          by hugocarmo
          Hi.
          I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
          It is imaculate inside, almost no dust or debris inside.
          The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
          So I started to look for a service manual, I found one, and started from the beginning.
          Most of the times the caps are the problem so I orderer all the caps for all boards,...
          04-26-2025, 07:45 PM
        • computeka
          Macbook Air A2337 820-02016-07 No sound problem
          by computeka
          How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
          05-08-2024, 10:26 AM
        • Alija
          sound problem on my dell latitude 5300 2 in 1 laptop
          by Alija
          I have a sound problem on my dell latitude 5300 2 in 1 laptop.
          Sound was working on the laptop and I had 2 Intel drivers and one more. When I turn on a song on You Tube, there is no sound, I uninstalled the drivers and tried to install them again, but now in the device manager the sound card is not visible, it only has Intel HD
          Please help me
          08-02-2022, 12:31 AM
        • cazi1001
          Samsung Galaxy A22 - strange problem with sound / speaker
          by cazi1001
          I have a Samsung Galaxy A22 5G with a strange error image.
          If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
          If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
          If I listen music via Youtube, even the upper or lower speaker don't work.
          If I switch louder or quieter, the sign on the screen show me a headphone.
          If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
          Does anyone have any ideas, what the problem could be?​
          02-10-2024, 09:16 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
