Sony 46w5500 repaired but wrong model number
  • o3365566
    • Nov 2012
    • 31
    • france
    During a storm my 46w5500 was dead with 8 red blinks.
    I successfully repaired it replacing the motherboard with an used one (with the same reference).
    However in the system menu I have 40W4710 as model number.
    I think that the model number is stored in the motherboard firmware. I'd like to know if is it possible to change it and how?
    I think that a service tool from sony exists to do that. Am i correct?
    Otherwise I located 2 eeproms on the motherboard and probably the firmware is stored there. I could prabably dump the old one from the broken motherboard and program the new one or simply swap them?
    Any idea?
    Thanks in advance!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Sony 46w5500 repaired but wrong model number
    If the set is now working correctly--Is there much point in going to the trouble of changing eeproms --with possible bricking it,--Just to change the menu model-number....?
    TELEFIX
    • Agent24
      I see dead caps
      • Oct 2007
      • 4963
      • New Zealand
      Yeah, if it works, I'd just leave it alone...
      That said, you might want to check that the new board is driving the rest of the set correctly... Theoretically the wrong firmware may cause damage... but I don't really know.
      -David VanHorn
      • o3365566
        • Nov 2012
        • 31
        • france
        No and... yes!
        I have different reasons:
        1. The first one is that it took me about 3 months of worldwide search to find the right motherboard with exactly the same reference number. Many other cards were availables which looked exactly the same but with different last 2 digits in the reference number. Vendors told that they didn't know if they could work in my tv or not. Thay talk about different firmware versions so I thought that being capable of reprogramming the firmware could make easier to swap motherboards from one model to another.
        2. Features : my tv is newer than the tv model the motherboard is from. So now it lacks some features like dlna and probably image processing is not the same.
        3. Knowledge!
        So if someone had done it before or has informations on tools for firmware motherboard programming for sony tv, any help would be appreciated.
        Thanks!
        • o3365566
          • Nov 2012
          • 31
          • france
          Another good reason!
          • Agent24
            I see dead caps
            • Oct 2007
            • 4963
            • New Zealand
            EEPROM swap would be easy, with the right soldering gear.
            If you get an EEPROM programmer you can probably read back the ROM too.
            If you feel confident, try that and see what happens. But if you trash the EEPROM you may be waiting another 3 months...
            -David VanHorn
            • kasfamily
              • Aug 2014
              • 768
              • Russia
              If you want, you can change the memory chip from the old board, but perhaps there is corrupted firmware as 8 flashes. Or use a service mode 2 change. As an example ....
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                TBH--I dont think the reasons that you list are enough to warrant the possibility of damaging the replacement board. As is, The board wont damage anything else as its working correctly.
                If DLNA is not functional in that board, it may not be JUST the firmware that is different--Maybe there's other parts not fitted/different to that board needed for it.--Happens all the time.
                Installing a different/wrong F/W for THAT version board may well brick it, as you did say there's an age difference too.....
                If it aint broke--Dont 'Fix' it!
                TELEFIX
                • o3365566
                  • Nov 2012
                  • 31
                  • france
                  Great! Could you explain some more on service mode 2 change? What document is the photo from?
                  My service manual for EX2L-Basil CHASSIS doesn't have any details about service mode configuration. It tells just how to enter and save data but no explanation about different parameters.
                  Thanks!
                  • o3365566
                    • Nov 2012
                    • 31
                    • france
                    Really? Is it possible to have motherboards with differents parts but exactly the same reference number?
                      Depends on which reference number you refer to, the one printed on the board or one on a sticker? Board print usually just keys for the blank version of that board, which can be loaded in many possible configurations (with/without DLNA capable processor for example)
                      • o3365566
                        • Nov 2012
                        • 31
                        • france
                        OK, I understand. In effect I was talking about the number is printed on the board. I will check the reference number on the sticker too. Thanks!
                        • tibimakai
                          • Jan 2012
                          • 3680
                          The sticker number counts the most. Look up shopjimmy too, what they suggest to do when this board is replaced, most like a firmware update.
                          • piernov
                            Beginner's guidelines
                            by piernov
                            You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
                            There are 2 situations:
                            1. You just want your laptop fixed
                            2. You want to learn about fixing laptops
                            Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
                            Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
                            If you are in situation number 2, then please continue and...
                            09-20-2020, 09:46 AM
                          • diamon
                            Changing model number 5500 to 5510
                            by diamon
                            I would like to place a Dell Latitude 5500 (black color) motherboard into a Dell Latitude 5510 (silver color) chassis .
                            How can I change the model number of this laptop?.
                            When you're entering the bios (F12), you see in the left corner Latitude 5500, I would like to have this changed into Latitude 5510
                            I have already edited the 5500 bios bin file with HxD, and changed the 5500 into 5510, but after re-flashing and soldering the chip back, the name in the left corner is still Dell Latitude 5510 (have entered the ServiceTag of the 5510 chassis).
                            Have uploaded the original...
                            06-19-2025, 03:25 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • mauda
                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                            by mauda
                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                            05-21-2023, 11:56 PM
                            Sony VAIO VPCEA3S1E/V Specification for Upgrade or Repair
                            This specification for the Sony VAIO VPCEA3S1E/V can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEA3S1E/V boardview and VPCEA3S1E/V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                            09-06-2024, 05:27 AM
