Panasonic TX-P42C2l : No Power with 4 LED Blinks
  • dulipra
    • Mar 2015
    • 41
    Re: Panasonic TX-P42C2l : No Power with 4 LED Blinks
    thanks. IC 771;
    Gnd - Out = 5.74k
    Gnd - In = 1.72k
    IC 773 (I don't sure about pin names. So I have mentioned the pin numbers mentioned on the board)
    Gnd - 1,5 = 5.74k
    Gnd - 2 = 1k
    Gnd - 4 = 9.37k
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by dulipra
      thanks. IC 771;
      Gnd - Out = 5.74k
      Gnd - In = 1.72k
      Gnd - 1,5 = 5.74k
      Gnd - 2 = 1k
      Gnd - 4 = 9.37k
      Well that looks like they've survived
      • dulipra
        • Mar 2015
        • 41
        Great really appreciate your help. I ordered everything i need from utsource. So will take 2,3 weeks.
        Also can you let me know if it is possible to replace that power board capacitor (1000uf 230v) by 1000uf 250v or 1000uf 200v?
        If not let me know if there any shop like utsource. cheers
        • tw2005
          • Oct 2011
          • 6458
          you'll have to match or go higher in voltage and I'd check the datasheet of whatever brand and series it is to something as good or better. Nichicon, rubycon etc.
          I'd stay away from chinese sources for caps. I don't know who's in the UK, RS components, element 4
          • dulipra
            • Mar 2015
            • 41
            I found a closest match. please can you check it for me.
            http://uk.rs-online.com/web/p/alumin...itors/7435438/
            • tw2005
              • Oct 2011
              • 6458
              It would help to know brand and series of cap that's in there. I'm not a cap expert but that one only has 3000Hr life rating.
              maybe http://uk.rs-online.com/web/p/alumin...itors/7149284/
              • dulipra
                • Mar 2015
                • 41
                Hi just received the parts and replaced all the parts. But still I have the same 7 blink problem. Now I can see the SC board LED turning on. but go back to 7 blink mode after few seconds.
                • dulipra
                  • Mar 2015
                  • 41
                  Sorry it is 6 blinks now
                  • dulipra
                    • Mar 2015
                    • 41
                    Hi, after replace the parts, it becomes 6 blinks.
                    • dulipra
                      • Mar 2015
                      • 41
                      do you think still it is SC board? please let me know what should i check now.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Not good I guess. Not sure how I'll go recovering from a failed attempt.
                        Are you able to take a hi res photo of the board so I can see repairs? Can you list the parts(locations) replaced?
                        Did anything go pop when you powered this board up?
                        have you gone back and now checked all those parts to see if any are damaged/shorted after the power cycle?
                        Q661 is one that comes to mind
                        I'm hoping you ordered extra quantities of parts for more than one attempt.
                        • dulipra
                          • Mar 2015
                          • 41
                          Please check the attached pic. checked the Q661 and its not shorted. and the other parts i replaced are looks fine. not shorted.
                          • tw2005
                            • Oct 2011
                            • 6458
                            I'm going to dribble out the info as I work out what those parts are.
                            Check D451 for short cct
                            Also looks like no 30f125 transistors replaced. Is that correct?
                            can you provide a summary of the part numbers of those heatsinked parts replaced, that will save me a lot of time.
                            • tw2005
                              • Oct 2011
                              • 6458
                              What is Q621?
                              • dulipra
                                • Mar 2015
                                • 41
                                Replaced parts:
                                Q661, 401, 402, 421, 422, 451
                                D482
                                IC521
                                Q451 - C & E shorted
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Replaced parts:
                                  D482
                                  IC521
                                  I think we're not understanding. I'd like the part numbers eg RJP63F3A etc
                                  Check the SMD diode D451! The fact you report shorted C-E I think is pretty much confirming D451 is shorted, that will cause 6 blink and funny buzz
                                  would like to know what Q621 is and also can you resistance that one g-c,g-e c-e.
                                  Please
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Actually if Q451 is short c-e, just remove that D451, recheck c-e, ,
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      you'll need either RF071L4S(original), RF101L4S(higher peak) (400V 1A) or something equivalent. super fast recovery diodes
                                      • dulipra
                                        • Mar 2015
                                        • 41
                                        checked D451 after removed. it is not shorted. transistor is fine. But the C & E points on board is shorted.
                                        Pls can you let me know that diode part no on the board.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Ok , this is weird. So out of cct, D451 is ok, so too is q451 out of cct but at the board c-e is?
                                          I was confident i was right but looks not. we're close. Thinking Q551
                                          Let me think. I may be misunderstanding the schematic.
                                          back soon
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                            03-31-2024, 02:12 PM
