Samsung LE37B554M2PXXN. Color problem.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    I picked this 1 up together with the LG plasma and this 1 has a problem.
    When it starts up ( cold) the screen is fine for a few secs and then it changes to less bright and then it goes like the screen as you can see on the pictures.
    The snow signal changes from black white to yellow/black.
    When i press menu or source the option menu is barely visible. It can show red + green. For example the words "HDMI 1 " is red colour.
    My guess is T-con or backlight?
  • DemonBG
    • Mar 2012
    • 143
    Re: Samsung LE37B554M2PXXN. Color problem.
    the fact that it gets less bright MIGHT suggest this is a power board issue (Check caps) but also could be T-con / Panel as well...
    Can you post a clear picture of the PSU as well please?
    Good luck,
    Demon
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Hi Demon ,
      Thx for the reply! The second picture is the power supply , all caps look good.
      Ill try to get a more clear picture.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        This is the power supply
          T-con board, check gamma voltages.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Will do that tomorrow.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              I might first try to reseat all the cables.
              T-con boards , are they repairable? Or should i just replace the board?
              What about cleaning the cables with WD40? Sometimes the picture is also flickering.
                If you have a gamma chip fault, yes, they're repairable, it costs very little. Post a picture of your T-con board.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Not possible right now , im at work.
                  Will do that after 5.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    I wanted to measure gamma but i dont see the gamma chip? No words with gamma....
                    Ps the picture is now black with some red spots.
                    You dont think its PS?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Sometimes i see the menu flash... Bright, less bright
                      Its fading slowly to dark
                        Test points marked VG1, VG2, ... up to VG22. Check each voltage and report back, not all will be available.
                        • flocko
                          • Nov 2012
                          • 1121
                          Test points for gamma voltage marked VG1<->VG22 they are a little scattered across the top of the board (black probe to T.Con fixing screw ,red to test point meter set to 20v DC) and list
                          VG1xx
                          VG2xx
                          VG3xx and so on Flocko
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            VG1 : 7.54
                            VG2 : 7.54/55
                            VG : 4 = 7.43
                            VG : 12 = 11.73
                            VG : 13 = 11.87
                            VG : 14 =
                            VG : 15 = 8.02
                            VG : 17 = 12.21
                            VG : 18 =
                            VG : 19 = 12.19
                            VG : 21 = 0.90
                            VG : 22 = 0.34
                            These were the first that i found on the board but i already noticed that its not good right?
                            Is this a cap problem or the chip?
                              The gamma chip is bad. (AS15 on T-con.) Common fault.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                Ok thx, will order new tcon.
                                  AS15-F can be replaced with hot air gun.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    Hmm ok will try that first! What about reflow?
                                      IR reflow would work, but not global reflow. What do you mean? You will have to remove the chip and install a new one, the chip is about 3 euros.
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        Very rare do those power supply/inverter boards have failed caps, they mostly fail due to bad inverter transformers for FYI.
                                        I have several of those on hand, each one of them has failed via transformer/s.
                                        As you have already uncovered your gamma is bad. Just watch out for these transformers, if you hear a Bzzzzzz or notice one is getting hotter then the other I would replace it ASAP before it burns up and possible burns a hole in the board ect.
                                        Just an FYI for future maintenance!
                                          09-07-2024, 05:50 AM
                                        • StromarMiki
                                          Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
                                          by StromarMiki
                                          Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help....
                                          11-06-2021, 06:32 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                          09-06-2024, 11:40 PM
