LG 42PJ150. Clicking Clicking Clicking
    Re: LG 42PJ150. Clicking Clicking Clicking
    Ok, this indicates a problem with the power board.
    On the regulator you suspect to be bad, try checking Vcc voltage of it. To find out which pins/components to measure across locate the datasheet of the IC. Your ground reference will be on the negative of the large 450V capacitors or other primary-side ground (note the mains ground is not a primary side ground.)
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      #42
      Here is the picture with the wires.
      Gnd/gnd the voltages keep changing fast from 1.7 to 2.1
        Also, have you checked ALL primary-side fuses?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          #44
          All big fuses are ok.
          I dont know to test a 6 legged regulator.
          The big pin with eys1 measures 190v
          The other pin at the end measures 1.6 and when it clicks it says 0 and then 4.5 dropping to 1.6
          The 4th pin in the middle is 0.4v
          The pin next.to it measures 0.03v.
          Other pins i cant reach..probes to big
            I gave you instructions, it's pretty simple, you want to learn?
            To clarify you'll be looking a pin marked Vcc or Vs and also checking the datasheet for the range of acceptable voltages (UVLO voltage / start voltage / stop voltage)
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #46
              Ok thx i understand!!
              • discharge
                • Nov 2014
                • sweden
                #47
                Originally posted by Moreno83
                So this is the set, bought it from people who smoke alot as you can see haha.
                The cable on the left of the PS going to the board on the let has 0v on all pins.
                The cable on the PS righthand side is going to the maonboard and has 4v and 5v. ( 2 pins next to eachother)
                I think 5V is stby out from psu and 4V is power on from main.
                Maybe connect an external dc so this 4V reach 5V and see whats
                happen.
                • discharge
                  • Nov 2014
                  • sweden
                  #48
                  Just a short time at first.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    #49
                    Thx for the replies.
                    Tom , I'm having trouble finding the voltages as they should be. I downloaded the schematic but it does not mention the out coming voltages on that regulator. It only mentioned the 1.8v which i measure. ( schematic is only 5 mb orso )
                    Maybe i'll just order the repair kit? It has the regulator/diode/resistors because i just found a short diode next to the regulator. Its open on both sides.
                    I measured the fuses for continuity and ohms in the primary section and they are all ok. Rest of the diodes are also fine.
                      You need to be looking at the part on the POWER BOARD, find the datasheet (not schematic) for the part you suspect to be bad to learn how to check it.
                      To find the datasheet you'd search for a sequence of numbers and letters on it e.g. 3BJR089K.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        #51
                        I know , but i can't find the data sheet so i looked for the schematic.
                        I measured like you said and i get the following :
                        385V ( Keeps changing because its clicking , starts around 390 ).
                        2.9V ( Starts with 3.2v )
                        0.9V
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #52
                          Wich means the regulator is doing its work right?
                            No idea until a datasheet is found to be honest, what is printed on the device?
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #54
                              Yes i understand but just googling for it did not help so i can't compare.
                              3PAGC10014A-R
                              Could not find it on your site. :-)
                                Isn't it 3BR1565JF?
                                http://www.datasheetbank.com/datashe...3BR1565JF.html
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #56
                                  Hmz , will look at the board again but what i wrote down is printed on the PS haha.
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    #57
                                    Pff , need to work on my english and read better ……
                                    Sorry , you are correct thats the part number/data sheet.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #58
                                      I checked the data sheet but i don't see anything that i can use. I have to say that this is all new for me so if you can learn me something …i would appreciate it
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        #59
                                        Hi Tom ,
                                        That datasheet you provided is the basics of the regulator/controller. It does not say the voltages i must measure with this particular tv/powersupply.
                                        Any tips to guide me in the right direction ?
                                        thx for your time
                                        • marty-clubber
                                          • Oct 2014
                                          • 58
                                          • u k
                                          #60
                                          Hi
                                          Repair kit For your power supply Eay60912401
                                          R927 22ohm Resistor
                                          R929 22ohm Resistor
                                          ic301 3br1565jf regulator
                                          d304 Diode
                                          • bffargo
                                            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                            by bffargo
                                            LG 60PB66550 NOV 2014
                                            PSU: EAY63168603
                                            PCB: EAX65359531 2013.11.01 Rev:1.0
                                            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                            Symptom:
                                            While watching, just went black and started clicking relay every few seconds.
                                            Initial diagnosis:
                                            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                            Deeper diagnosis:
                                            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                            09-09-2022, 07:34 PM
                                          • alfredomfr1
                                            TV Plasma LG 60PN5000 ZSUS 15v missing
                                            by alfredomfr1
                                            All Voltages are OK except ZSUS 15v.
                                            YSUS board disconnected still 15v missing.
                                            ZSUS was replaced: 15v missing.
                                            Any help will be appreciated...
                                            04-29-2022, 11:26 AM
                                          • B0r1s
                                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                            by B0r1s
                                            PSU - BN44-00878A
                                            Symptoms:
                                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                            A weak clicking sound was coming from the transformer.
                                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                            Progress:
                                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                            01-17-2023, 04:58 PM
                                          • novak2
                                            Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                            by novak2
                                            Hello there,
                                            I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                            The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                            From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                            Thanks in advance.
                                            09-25-2020, 02:34 PM
                                          • reessi
                                            LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
                                            by reessi
                                            Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
                                            Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
                                            If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
                                            If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
                                            12-13-2017, 01:18 PM
