35x30mm 450V 150uF replacement
  • rustytierod
    • Sep 2014
    • 81
    2 exploded on a LG LCD tv PS board. Right behind a heat shield.
    Looking to anyone's expertise on this one. Trying to keep the dimensions the same since its in a little foot print. can't find single ones for sale without the 30 week lead time!
  • mockingbird
    • Dec 2008
    • 5484
    Re: 35x30mm 450V 150uF replacement
    If you meant 35x30 (Width x Height), then here:
    http://www.digikey.com/product-detai...C30-ND/2428153
    Will cost you some.
    • rustytierod
      • Sep 2014
      • 81
      I just found some on ebay that are 30x30. What could possibly be the difference?
      • rustytierod
        • Sep 2014
        • 81
        I guess the digikey ones are rated at 105C?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          yes rated 105c
          • rustytierod
            • Sep 2014
            • 81
            So given another cap with the exact same specs, but slightly different dimensions and in this case smaller volume, 30x30, is there some difference that would create a problem?
            Is there some difference in the dielectric design to keep uF the same?
            • mockingbird
              • Dec 2008
              • 5484
              Don't buy capacitors off eBay. They're fakes and are also probably under-spec.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                Different manufacturer, different design possibly, different electrolyte formula etc.
                If the new capacitors are smaller, you should probably check that the ripple current rating is not lower than the originals, if it is, you may get problems. Of course, newer capacitors can be designed better and fit the same thing in a smaller can, so the answer is.. It depends.
                Check datasheets of both
                But I would be worried about what caused them to explode in the first place... AFAIK only CapXon HP were known to self-destruct, for anything else, suspect a problem elsewhere in the circuit causing overvoltage.
                If they are mains filter caps in PSU without PFC, likely you have a screwed bridge rectifier (or someone replace it backwards or something)
                -David VanHorn
                • rustytierod
                  • Sep 2014
                  • 81
                  They were "SAMWHA" make. I don't know how to tell if there is power factor correction (that is what you mean)?
                  • mockingbird
                    • Dec 2008
                    • 5484
                    I have had a primary capacitor explode on me in an LCD TV because the bridge rectifier failed. You might want to check that out.
                      At 450Vdc rating, then it will have PFC Voltage booster circuit.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5037
                        • New Zealand
                        If it has PFC, perhaps the PFC controller went nuts and boosted the voltage far too high?
                        -David VanHorn
                          That is one possibility, tom66 had that experience with out of regulation of the PFC Voltage booster circuit.
                          • rustytierod
                            • Sep 2014
                            • 81
                            Some smaller 2200uf 10v caps nearby had buldged on top but not exploded. I should note only one of the filter caps actually exploded. The other just got really bloated/buldged.
                            The TV was becoming dimmer and dimmer to watch and would take longer and longer to get a picture on the screen and eventually wouldn't power on at all (at which point I assume large cap exploded).
                            You ARE probably right about the bridge shot, it must be open circuit since those big caps are only in parallel with line.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5037
                              • New Zealand
                              Can you post photos of the capacitors in question?
                              I'm starting to think you mean they have vented, rather than exploded... you would have heard them if they had literally exploded.
                              -David VanHorn
                              • rustytierod
                                • Sep 2014
                                • 81
                                Your right, looks like one leaked in the direction of gravity.
                                  Just SAMWHA caps that failed.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    Yeah those haven't exploded, or they would be in little pieces all over the inside of your TV. (Yes, it can happen!)
                                    Clean the leaked electrolyte off the board, replace the capacitors. If the other output ones are Samwha too, or any other cheap brand, you should replace the lot at once.
                                    -David VanHorn
                                    • rustytierod
                                      • Sep 2014
                                      • 81
                                      You can't see very well, but the little ones buldged too.
                                      • rustytierod
                                        • Sep 2014
                                        • 81
                                        Replaced those 4 to start, no diff, 6 green flashes no back light or picture
                                        • shovenose
                                          Source for quality stumpy 450v/150uF STGCON cap replacement
                                          by shovenose
                                          I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
                                          The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
                                          Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
                                          08-17-2021, 10:47 AM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
