Sony Bravia LCD TV KDL- 46XBR4
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    A friend says that her TV (KDL- 46XBR4) takes 20 minutes to "warm up," but after that, it has a normal image.
    Is this an easy-to-fix problem?
  • JuniperSprouts
    Solder Soldier
    • Aug 2010
    • 119
    Re: Sony Bravia LCD TV KDL- 46XBR4
    Either inverter or CCFLs or PSU?
    • JUCaESAl
      Sony bravia KD-65AF9
      by JUCaESAl
      Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
      Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
      10-20-2025, 04:03 AM
    • PopsCaps
      Sony Bravia KDL-40V2500 that will not power on
      by PopsCaps
      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
      I do not hear any sound and I cannot see any backlight.
      I have tried disconnecting every cable on each board one at a time to see if anything changes.
      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
      03-25-2025, 11:23 AM
    • alegatorul
      sony bravia kdl-43w756c, no power, no sound
      by alegatorul
      the charger brick has 19,2-19,3 vcc
      changed the inverter board same result.
      where should i start?
      cheers
      11-15-2025, 10:00 AM
    • justin35
      Sony bravia kdl-43w755c - boot loop
      by justin35
      i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
      from what i read online it looks to be an emmc issue…
      i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
      i took out the board and say an samsung 16gb emmc
      i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
      i could try to put one instead of the 16gb one, but will it work?
      where do i get the software from?
      any help will be much appreciated!...
      03-06-2024, 12:26 PM
      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
      10-16-2024, 05:15 AM
