Polaroid FLM-3232 no standby power
  • triplefour
    • May 2014
    • 1747
    got this tv for 10 bucks and when i first plugged it in, it worked fine for at least 6 hours. the next day it would not turn on at all. i dont even get the red standby light when plugged in. i see 165v at the main filter cap, but on CN3 where i should see some pins with 5v i only see a fluctuating voltage going from around 2.7v to around 3v.
    i lifted the leg of what i thought was a diode to test if it was shorted but im thinking that cant actually be a diode because it doesnt have a stripe saying which side is which...and it says J3 not D something...is it just a jumper? why does it look like a diode without a stripe then?
    still not psu savvy enough...what should i test?
    Don't fear the repair...
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Polaroid FLM-3232 no standby power
    That is a ferrite bead. It's like a jumper, but also with a ferrite bead.
    The black ferrite bead is there to reduce high frequency noise.
    Try warming the board around the areas of C62, C15, and D7 (what is the number of the capacitor right below D7?) with a hair-dryer. If it makes the 5V standby come on, then one or more of those small electrolytic capacitors has/have gone bad, and will need to be replaced.
    Muh-soggy-knee
    • triplefour
      • May 2014
      • 1747
      dang..would u believe no one in this bachelor pad has a hair dryer?? thanks for the tips...ill go pick one up and try it. the capacitor right below D7 is labeled C19
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • asr
        Finding replacement diode iPad Pro 3rd gen A1701
        by asr
        Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
        Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
        07-09-2024, 06:24 PM
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • Baste
        MBR3045CT and SR3045LCT Schottky diode testing help.
        by Baste
        Hello experts,
        Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
        Aneng ST182 Meter.
        Diode mode.
        MBR3045CT:
        Diode mode
        Pin 2-1 - 0.150v
        Pin 2-3 - 0.150v ...
        10-21-2025, 06:14 AM
