Sharp LC-40LE510E Green color only
  • Andreasbest
    • Aug 2014
    • 1169
    • Hellas ( Greece )
    Hello.
    I have a LC-40LE510E that displays only green color and if left on same channel for some seconds then it fades out until black, when i change channel it gets bright green then fades again and so on.
    I have taken photos of all boards and symptoms but since that seems mostly like a T-Con issue i taken lots photos of it.
    Unfortunately the service manual isn't available to public so i count on your experience
    Re: Sharp LC-40LE510E Green color only
    Looks like a defective LCD panel.
    This TV is made by VESTEL not Sharp, it is just re-badged and is absolute junk.
    Maybe try checking panel voltages on T-con board, non replaceable part.
    • Andreasbest
      • Aug 2014
      • 1169
      • Hellas ( Greece )
      Damn... Do you have any idea where should i measure and what voltages should i expect ?
        VGH = about 20 to 30V
        VGL = about -5V to -10V
        AVDD/VDD = about 14V to 16V
        those are the key ones, all measured with chassis ground as negative.
        • mmartell
          • Oct 2013
          • 3189
          Originally posted by Dxmen2
          Hay tom i have a 42 Inch plasma i got a main board from a 50 Inch tv both Samsung same part number the pic is not cenered
          Can u help mr tom trying to fix tv for granpa
          Are you serious right now ?
          Stop crapping here or at least find a thread that's similar to your problem or create your own thread.
          • Andreasbest
            • Aug 2014
            • 1169
            • Hellas ( Greece )
            Ok i'll take the measurments on Monday that i'll return, meanhwhile can you please explain me in which way can a lcd panel get defect?
            I mean it doesn't contain any pcb or any components, so how the glass and the printed lines on it can get defect and display only green like in our situation?
            I'm a noob on lcd repair, so please excuse any foolish questions i might ask
              There are chips bonded to the panel on those little orange ribbons. 99% of the time they are what fails. Exactly why, I don't know, they seem particularly predisposed to do it.
              • Andreasbest
                • Aug 2014
                • 1169
                • Hellas ( Greece )
                Whoa, didn't knew there were more components after the T-Con board.
                Do you have any photo to get any idea of what we are talking about?
                  None myself but any time you take apart a cracked LCD have a look at the chips. On the newer panels there are only a few, so they seem to fail more often due to too much heat. They control the columns of the display (SOURCE driver.) Sometimes there are external GATE drivers for the rows, other times these are built into the panel itself. Lead free solder bonding underneath them might be a failure point, but I have tried reflow with no success.
                  • Andreasbest
                    • Aug 2014
                    • 1169
                    • Hellas ( Greece )
                    I see. So perhaps the green color on my LED tv is indeed a faulty panel, i wish not
                    • Andreasbest
                      • Aug 2014
                      • 1169
                      • Hellas ( Greece )
                      Finally managed to get the manual for free.
                      I'll check the measurments you suggested and the manual later that i'll return to the bench.
                      Meanwhile keep the service manual for the records, it's very rare for free.
                      • Andreasbest
                        • Aug 2014
                        • 1169
                        • Hellas ( Greece )
                        Ok i'm on the set now, i checked the t-con but i can't found any VGL or VGH , although i can found VGL_L and VGL_H, also no AVDD/VDD.
                        Can you please point me out?
                        • Andreasbest
                          • Aug 2014
                          • 1169
                          • Hellas ( Greece )
                          Anyone out there to point me the test points on pcb pictures???
                            Try VONE and VOFFE if you can find them, as well as VGL_L and VGL_H.
                            • Andreasbest
                              • Aug 2014
                              • 1169
                              • Hellas ( Greece )
                              Ok, replying in a while.
                              • Andreasbest
                                • Aug 2014
                                • 1169
                                • Hellas ( Greece )
                                VGL_H = 7,81 and VGL_L = 0.5v (suspicious)
                                No VONE or VOFFE test points as i see.
                                  I can see at least one point marked VONE_28V and one marked VOFFE_7.5V or similar.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1169
                                    • Hellas ( Greece )
                                    Hello again.
                                    Sorry for the huge delay but i left this tv set on the side for a while to complete some more urgent work.
                                    Now i have plenty of free time and i catch it again, so the voltage on VONE_28V is 31v and on VOFF_-11V is -11v seems everything is fine on those 2 checkpoints.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1169
                                      • Hellas ( Greece )
                                      Plus i got 2 great news, i completely disassembled the panel and found 2 very promising facts.
                                      1) The panel is not Vestel , it's Samsung.
                                      2) The panel it self doesn't have any components on it only the printed lines, so i think the panel cannot be defected. I attach a photo too.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        That WOULD be great news if Samsung did not have an abysmal panel failure rate too as evidenced by the empirical data in this forum.
