LG 50PK series display issue
  • tobias
    • Oct 2014
    • 5
    When I turn on my 50PK760 LG plasma the bottom part of the sreen has a border (visible right on top of the + on the first picture) that becomes darker a few seconds later (second picture). Then it starts to be distorded (third picture) to become and stay black (last picture). All this sequence takes approximatively 2 minutes.
    I am thinking of the bottom Y buffer board but there are no shorts after checking it.
    I checked VS: 201V and VA: 59V
    Any ideas?
    Thanks!
  • tobias
    • Oct 2014
    • 5
    Re: LG 50PK series display issue
    Pictures don't seem to work. Here there are direct links:
    http://img110.xooimage.com/views/3/b...--47e8db2.jpg/
    http://img110.xooimage.com/views/9/a...--47e8db4.jpg/
    http://img110.xooimage.com/views/6/c...--47e8dbc.jpg/
    http://img110.xooimage.com/views/9/e...--47e8dc7.jpg/
    http://img110.xooimage.com/views/8/e...--47e8e09.jpg/
    • tw2005
      • Oct 2011
      • 6458
      Best way with pictures is to go advanced, manage attachments and upload as thumbnails.
      I'd go with bad lower buffer.
      I have seen something like that but no where as extreme on a 50PK550 which I'd expect to be the same board after i replaced a board shorted by a cockroach.
      Not greatly noticeable but the lower half did have a slightly dimmer display. Your first shot reminds me of that but yours is much worse.
      Sounds heat affects the fault
        I agree, bad lower buffer
        • tobias
          • Oct 2014
          • 5
          Thanks for your prompt replies. I'm leaning toward lower buffer also but there are no shorts and by touching the heatsinks no one is hot compared to the upper buffer board.
          Also, control board led is blinking once normally then right after flashes once and so on.
            Try using a household hair dryer to heat up the upper & lower buffers - see if the fault occurs quicker then.
            • tw2005
              • Oct 2011
              • 6458
              The bottom buffer is only$20 and ysus $40 at SJ, very cheap compared to most plasma Tv parts. Could replace the lot at $80
              • tobias
                • Oct 2014
                • 5
                Just an update for those who might have the same issue in the future. It was indeed a faulty lower buffer. Works like a charm now.
                Thanks to tw2005 and tom66 for their help.
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • Norag33
                  HP 15-da0073wm display issue
                  by Norag33
                  Hey guys i need your help to fix this problem with this HP 15-da0073wm i7-8550U, this laptop originally has a 40 pin display connector for the Cell Touch eDP display and since i couldn’t acquire that display i decided to adapt the 40 pin connector to 30 pins discarding the touch related pins since the first 30 pins are the same as non-touch eDP displays, the problem is that it worked but not as i expected, you can see the problem in the pictures, i already tried to isolate the display cable from external interference or i think so, i tried with other displays but no video just black screen,...
                  07-05-2025, 03:40 PM
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                • MDY94
                  Hitachi 50HK6100U display issue
                  by MDY94
                  I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                  12-18-2024, 12:31 PM
                • CyberPhoenix
                  Issue with picture quality of Sony bravia TV
                  by CyberPhoenix
                  Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                  01-22-2024, 02:08 AM
