Plasma Flicker/Color Problems (Pioneer PDP-V401)
  • hyperfox
    • Sep 2014
    So I found a local PDP-401 Plasma TV for cheap and decided to pick it up. I'm into retro gaming so a 4x3 plasma is just great, so it's old I know haha. However it has a few problems. ...namely with the red and blue. It has this weird flickering effect and the colors are sometimes messed up:
    https://www.dropbox.com/s/naj7evgimv...81409.mp4?dl=0
    Any ideas?
  • pixelcap
    Pioneer Plasma 111FD To Solder or Not to Solder.
    by pixelcap
    Hello out there in Badcap land.
    I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
    are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
    Thank you
    Pixelcap...
    03-08-2025, 07:10 PM
  • Eaglecrest
    Panasonic plasma color stripe
    by Eaglecrest
    I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
    11-05-2025, 06:16 PM
  • fixit007
    Samsung flicker - BN44-00932T board or else?
    by fixit007
    I picked up this TV that the prior owner said - just died.
    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
    05-04-2024, 06:14 PM
  • DrvLikHell
    Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
    by DrvLikHell
    Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
    The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
    07-05-2024, 02:54 AM
  • Phil Stasik
    Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
    by Phil Stasik
    Pioneer Pro-FHD1 Elite. Failure to power on.
    I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
    We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
    01-19-2023, 01:22 AM
