Smsung HLN507W powerbutton replacement
  • cadar21
    • Oct 2010
    • 53
    hey guys someone broke the powerbutton on my tv...
    the silverbutton cover is missing and the powerbuton itself is broken i can see its only connected by 2 of its 4 solderpoints...
    Do i have to remove the whole back cover to get to that panel to resolder the joints or is there a shortcut.. this is not a priority qs.. it just anoys me that i need the remote to turn the tv on because the buttons broken..
    id appreciate any help...
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • ezenia
    Alba CBB16 replacement switches
    by ezenia
    I've been given an Alba CBB16 radio to look at. The issue was no sound from either speakers when switching to the radio. They'd just be some buzzing/static. I did some troubleshooting and found that if I mess with the switch in certain ways, the sound cuts in and out on the right channel speaker. It'll go from quiet with some static/buzzing to really loud and clear depending on how the switch is moved. This told me that the radio at least has an issue with this switch.
    The switch appears to be broken on the inside causing a poor connection. I tried cleaning it...
    07-29-2024, 07:05 PM
  • Glaval
    Sony OLED XBR-65A8G 4 flashes
    by Glaval
    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
    01-23-2025, 04:04 PM
  • chth96
    Is it possible bridging tiny broken trace
    by chth96
    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
    cutting tiny trace.
    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
    12-03-2022, 11:32 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
