Which Multimeter to test Vizio sv422xvt
  • fredrock46
    • May 2014
    • 22
    I'm trying to fix my Vizio SV422XVT TV. It won't turn on. The logo just flashes orange/white. From the posts I've read it seems the problem is most likely the main board. Could you recommend a multimeter I could buy? The cheapest I could get away with as I will seldom use it. Could you also point me to a tutorial for using it?
    If it turns out the problem is the eeprom will I be able to replace that on this TV? Thank you in advance.
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Which Multimeter to test Vizio sv422xvt
    cheapest multimeter thats somewhat accurate is at harbor freight. It does sound likely that your eeprom is corrupt, it is a 8 pin dip, you would have to desolder and resolder. That is if you can find it, shop jimmy doesnt have any listed for your model.
    Liberating magic smoke one part at a time
    • fredrock46
      • May 2014
      • 22
      Thank you for checking for the part on ShopJimmy and getting back to me.
      They don't have the main board in stock either. I put an alert on that but I can't find any listing for the eeprom. eBay doesn't show an eeprom repair kit for it either.
      Would you be able to identify the eeprom on the main board picture I've attached here. I thought I might be able to see a part number on it with a magnifying glass if I knew it's location.
      Also, are there places you can send a board to have it diagnosed and repaired?
      Oh and the multimeter link you sent me is just what I'm looking for, thanks.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        I circled the 8 pin dip in red and the one I think likely to be the eeprom with 3 red.
        Moduslink has a good reputation for fixing main boards. You should check all the voltage regulators as well as one out of spec could cause similar trouble, I circled the 3 I see in orange, also 3 fuses in yellow you can check for continuity.
        • dj8452000
          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
          by dj8452000
          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
          02-18-2025, 08:28 AM
        • jinu_j
          How to test Subwoofer Amplifier with only a multimeter
          by jinu_j
          Hi Folks
          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
          Problem
          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
          Any advice would be appreciated...
          08-29-2024, 02:05 AM
        • SidneyCanadas
          93C46 and 93C56 EEPROM
          by SidneyCanadas
          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
          06-14-2023, 01:16 PM
        • RDC55
          Vizio a320-a0 eeprom
          by RDC55
          I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
          Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
          04-28-2021, 09:06 AM
