Hitachi RPTV convergence issue
  • zacheriaj
    • Jan 2014
    • 138
    Hello, I am fixing a Hitachi rear projection and here is the issue. Convergence was bad so I pulled the board, replaced the STK392-110 ics with STK394-160. Checked all resistors and they are fine, no pico fuses to be blown. Put the board back in, power supply turned on fine, two faint clicks and the screen doesn't turn on. pulled the PSU and the Convergence board and find that E905 on the PSU is open and GF01 and GF02 on the convergence board are open. One cause that i'm wondering about is if the outputs on the flyback transformer matter or not. Those are the only three cables I forgot to mark like a rookie Obviously the middle CRT goes to the middle. With the PSU and Convergence board out, can I replace fuses and force on the PSU to test and see if they blow again? Double checked soldering and there are no bridges or bad connections.
    This is why I prefer to work on LED, LCD, and Plasma
    You Can't Succeed Until You're Willing to Fail
    Re: Hitachi RPTV convergence issue
    Yes the order of the connectors on the flyback really do matter!
    One is the EHT voltage (20~30kVDC), one is the SCREEN voltage (200~500VDC) and one is the FOCUS voltage (3~5kVDC)
    Getting them in the wrong order could destroy the tube(s)
    • zacheriaj
      • Jan 2014
      • 138
      So its possible that replacing the fuses and wiring those correctly will be ok then. If I didn't damage anything. The pico fuse that's blown is marked 3000 and the two cartridge fuses only have the letter T on them so not sure of the current ratings..
        Well, I don't know if damage has been done to the CRTs...
        • zacheriaj
          • Jan 2014
          • 138
          Say that the fuses caught it in time, what's the best way to determine which goes where? And how would I find the values of the fuses
          • R_J
            • 9535
            The three high voltage outputs on the flyback are the same,It does'nt matter which crt's hv lead goes into which connector on the flyback. GF01and GF02 are spark gaps they will check open.
            The pico fuses are marked in ma. 3000 = 3amp; 4000 = 4amp
            On some chassis's e905 fuse is for the +220v to the crt boards
            Best I can do without a model or chassis number.
            • zacheriaj
              • Jan 2014
              • 138
              Interesting because GF03 shows closed. When I plug it in, PSU starts fine just no power to the convergence board it seems. And I was mistaken its not e905 its e907 that's open. Any ideas?
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • MDY94
                Hitachi 50HK6100U display issue
                by MDY94
                I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                12-18-2024, 12:31 PM
              • navagator
                Hitachi 57F710E Power Issue
                by navagator
                I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
                I noticed on the bottom of the board there was a row of solder joints with voltages printed next...
                11-09-2023, 06:05 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
