Help-LG60PC1D
  • tech2014
    • Aug 2014
    • 807
    Help-LG60PC1D
    I have been working on this TV for a while now. I found the 5v line on the YSUS board was only 4 ohms resistance. I thought that was the problem, so I replaced the board. It STILL isn't working. When everything in the TV is connected, there is standby LED flashing and no sound from the TV, its dead. No clicking or anything.
    I decided to start removing one board at a time to see if anything changes. I found that when the bottom left buffer board is connected to the top, the voltages drop out. I also found that if the ZSUS board is connected to the bottom buffer boards the voltages drop out.
    I found that if I just have the power supplies connected to in the tv, the relays will click and I get all voltages for a few seconds then relay click again and voltages go to 0v.
    I have a DC power supply. I started inputting 5v to see the reaction (high current spike). I get high current and only 3.5V on the YSUS board when the top bottom and top buffer boards are connected. When I disconnect the bottom buffer from the top, the current is good and I get 5V.
    I also found that the voltages drops and current spikes when I have the bottom 5v connector on the YSUS board connected to the control board. When it is removed, voltages is 5v and normal current.
    I tried connecting 5v into the control board, but no current spike and 5v is good.
    I am getting frustrated with this tv. Can anyone give me some direction as where to go from here. Is the problem the control board or one of the buffer boards, or even the bottom boards.
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • MalodicOne
    Macbook 820-02773 Board short when trackpad connected
    by MalodicOne
    Original fault was customer spilled milk on unit, no corrosion was found on the board. Took mainboard out of original case and LCD and swapped it into the fully functioning case and LCD.
    Shorts show up all over the board when trackpad is connected only. Trackpad is used and fully functioning from another unit of same model. Voltage injection causes trackpad connector to get hot but nothing else, swapped on board connector to rule that out, same issue. Diode reading on IPD_MCU_INT_CONN is higher then reference board @ .935 expected is .803. Shorts show up on PPVBAT_AON_CHGR_REG and...
    03-31-2025, 09:54 AM
