Sony KE32TS2U 32" plasma panel.
  • Shinju
    • Mar 2014
    • 1239
    Hey friends!
    I got this pint sized Plasma display, it has a few lines down the left side that are not static in the fact they change color's and animate to the moving picture. I am hopping to get lucky and it will be just a dirty connection and all it needs is to be cleaned and reseated!
    Looks like the horizontal buffers are built into the screen/ribbon cable. I will post some photos of it later tonight / tomorrow.
    Its acctaully got a pretty nice picture for being a funky 825x1024 resolution 720p/1080i. Seems to have a ton of calibration functions too.
    I have never seen a plasma this small outside of a 32" Vizio anyone know of any plasma display that is smaller? I would like to find it if there is!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Sony KE32TS2U 32" plasma panel.
    LG made a couple of 32" sets, so did Hitachi--You'll have an Hitachi/Fujitsu panel in that Sony, I scrapped one about a year ago with a broken screen....
    Ive got an Hitachi 32AV3000 (Same panel and driver electronics),--but no media-box so its utterly useless, although does work, --test-paterns only. and am struggling with an intermittent suicidal LG 32PG6000 that keeps blowing IGBT intermittently....
    For TV's I think only LG and Fuj/Hit made small (32") Plasma panels, that some other makers, like Sony added their own signal stages (Mainboards etc) and boxed up as their own.....
    As I remember, That Sony 32" was built like a brick shithouse, it had a plastic rear cover, then inside another solid steel cover over the set itself!
    TELEFIX
    • Shinju
      • Mar 2014
      • 1239
      The Sony's AV connections are all built in. If they have Hitachi parts inside could you modify the one you have and use the Sony AV board?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        I was thinking of that. Trouble is, with all the crap I have, not sure whats what! I think I kept all that set's stuff together though, but quite where, in which box is anyone's guess!
        --I had to move a load of stuff quick when my job came to an end, some boxes I haven't opened since then....
        Its only the Y-SUS, Control-board, and X-SUS thats Hitachi, along with the panel itself. I Think the PSU was 'MITZUMI' or summit like that. Everything else was SONY as I recall....
        TELEFIX
        • Shinju
          • Mar 2014
          • 1239
          Ah, if the screen is bad on this one I actually found someone with a fully working screen lol not sure if I want to dump a ton of money into this little guy. If it was 1366x768 and had at least one HDMI (this one has DVI-I) I probably would spend a little more on it.
          I have been trying to track a 32" Vizio plasma for a while now, something to take to friends houses when we do xboxone group night gaming.
          • SurrealMustard
            What parts can be salvaged from a plasma with a damaged display panel?
            by SurrealMustard
            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
            03-09-2025, 08:29 PM
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • r3vsEngIT
            Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
            by r3vsEngIT
            65x900h with the panel from a 65x930d.
            900H: model yr 2020, Samsung panel
            930D: model yr 2016, Innolux panel
            spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
            the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
            07-11-2023, 11:11 AM
          • guidodroid
            Bad Panel in Sony Bravia X850G
            by guidodroid
            Hello all,
            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
            The issue is not as bad as others that I've seen around, but is indeed noticeable...
            03-19-2022, 12:08 PM
          • PlanB
            Sony KDL-55W828B Hotspot in LCD panel
            by PlanB
            Hello everybody,
            I need your expertise if my asumption about the failure of this TV is correct.
            A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
            When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
            When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
            I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
            02-05-2022, 09:46 AM
