Quick question - PS42C96HD
  • StephenU
    • Dec 2013
    • 230
    I have just done a full psu refurb on the above Plasma (Success).
    The front glass and plastic surround is cosmetically very poor along with the rear, I have a donor Plasma same model that is pretty much mint. My question is before i go stripping the full thing and changing over the front. Is there a way to remove the front rather than stripping the full unit and doing a swap over, never stripped one done that far as yet, but i do see clip like connectors down the side. Just wondering if i need to do the full strip down or is there a much simpler way. Thanks for any help in advance.
  • StephenU
    • Dec 2013
    • 230
    Re: Quick question - PS42C96HD
    Morning all, with regards to the above post I stripped and swapped over both fronts on the plasmas, only had to remove main board, holding plate and side AV assy, to be able to lift the entire Screen and all internal boards.
    Screwed them all back together and now have have a problem with one of them the other works as it should.
    I have removed the main board, gone over all connections etc. The fault seems to be like a strobe light effect flashing constantly, any ideas where to start or am i best just removing everything and reinstalling again, nothing was done any different from one unit to the next. Same parts removed, simple swap and screwed back together.
    • StephenU
      • Dec 2013
      • 230
      [[ Update - Model number is actually PS-42Q96HD and not PS42C96HD sorry for any confusion ]]
      • jimbofz
        quick plasma question lg 42 pa 4500
        by jimbofz
        with the tv unplugged and not in use:
        if a plasma screen has a yellowish patch or tinge
        is this a sign that the panel is gassed
        or worn?
        its hard to photograph
        but in daylight instead of being a uniform black,
        it looks yellowish in the corner ,theres no sign of cabinet damage.
        01-18-2021, 05:42 AM
      • ArMaaN376
        Samsung PS51E550 Plasma TV
        by ArMaaN376
        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
        Opened TV cover & observed foll
        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
        How to confirm Y -Buffer board...
        06-19-2024, 04:05 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • alltvrepairs
        Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
        by alltvrepairs
        I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
        I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
        Any one met this problem in the past?...
        10-08-2025, 07:34 AM
      • chazh
        LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
        by chazh
        This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
        I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
        The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
        09-01-2025, 08:56 PM
